Low throughput on RB2011 + E3372
Hey there!
I’ve got huge issues with RB2011 and Huawei E3372h-153. The problem is the slow DL/UL LTE throughput. I’m getting capped @ 21Mbps DL & 11Mbps UL no matter what.
Here is what I’ve done so far: Netinsall 6.44 stable on my RB2011; reset to blank w/o default configuration; with the LTE modem plugged in, RB2011 autmatically gives me option for LTE AP in Quick Set; lte-interface is then automatically created, and router is working fine otherwise.
Here is the verbose config export (minus the sensitive parts):
# mar/30/2019 23:57:11 by RouterOS 6.44
# software id =
# model = 2011UiAS-2HnD
# serial number =
/interface lte
set [ find ] disabled=no mac-address=0C:5B:8F:27:9A:64 mtu=1500 name=lte1
add ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=no \
    disabled=no fast-forward=yes forward-delay=15s igmp-snooping=no \
    max-message-age=20s mtu=auto name=bridge1 priority=0x8000 protocol-mode=\
    rstp transmit-hold-count=6 vlan-filtering=no
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled \
    arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
    4C:5E:0C:FB:A2:B5 mtu=1500 name=ether1 orig-mac-address=4C:5E:0C:FB:A2:B5 \
    rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=\
    4C:5E:0C:FB:A2:B6 mtu=1500 name=ether2 orig-mac-address=4C:5E:0C:FB:A2:B6 \
set [ find default-name=ether3 ] advertise=\
    4C:5E:0C:FB:A2:B7 mtu=1500 name=ether3 orig-mac-address=4C:5E:0C:FB:A2:B7 \
set [ find default-name=ether4 ] advertise=\
    4C:5E:0C:FB:A2:B8 mtu=1500 name=ether4 orig-mac-address=4C:5E:0C:FB:A2:B8 \
set [ find default-name=ether5 ] advertise=\
    4C:5E:0C:FB:A2:B9 mtu=1500 name=ether5 orig-mac-address=4C:5E:0C:FB:A2:B9 \
set [ find default-name=ether6 ] advertise=\
    10M-half,10M-full,100M-half,100M-full arp=enabled arp-timeout=auto \
    auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
    4C:5E:0C:FB:A2:BA mtu=1500 name=ether6 orig-mac-address=4C:5E:0C:FB:A2:BA \
    rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=ether7 ] advertise=\
    4C:5E:0C:FB:A2:BB mtu=1500 name=ether7 orig-mac-address=4C:5E:0C:FB:A2:BB \
set [ find default-name=ether8 ] advertise=\
    4C:5E:0C:FB:A2:BC mtu=1500 name=ether8 orig-mac-address=4C:5E:0C:FB:A2:BC \
set [ find default-name=ether9 ] advertise=\
    4C:5E:0C:FB:A2:BD mtu=1500 name=ether9 orig-mac-address=4C:5E:0C:FB:A2:BD \
set [ find default-name=ether10 ] advertise=\
    4C:5E:0C:FB:A2:BE mtu=1500 name=ether10 orig-mac-address=\
    4C:5E:0C:FB:A2:BE poe-out=auto-on poe-priority=10 power-cycle-interval=\
    none !power-cycle-ping-address power-cycle-ping-enabled=no \
    !power-cycle-ping-timeout rx-flow-control=off speed=100Mbps \
    tx-flow-control=off
set [ find default-name=sfp1 ] advertise=\
    4C:5E:0C:FB:A2:B4 mtu=1500 name=sfp1 orig-mac-address=4C:5E:0C:FB:A2:B4 \
/queue interface
set bridge1 queue=no-queue
set lte1 queue=no-queue
/interface ethernet switch
set 0 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch1
set 1 cpu-flow-control=yes mirror-source=none mirror-target=none name=switch2
set 0 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 1 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 2 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 3 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 4 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 5 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 6 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 7 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 8 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 9 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 10 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set 11 default-vlan-id=auto vlan-header=leave-as-is vlan-mode=disabled
set 12 default-vlan-id=0 vlan-header=leave-as-is vlan-mode=disabled
set [ find name=all ] comment="contains all interfaces" exclude="" include="" \
    name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" \
    name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" \
    include="" name=dynamic
add exclude="" include="" name=WAN
add exclude="" include="" name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet \
    default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk disable-pmkid=\
    no eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m \
    interim-update=0s management-protection=disabled mode=dynamic-keys \
    mschapv2-username="" name=default radius-called-format=mac:ssid \
    radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-sta-private-algo=none static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=\
    no-certificates unicast-ciphers=aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
    no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
    0 area="" arp=enabled arp-timeout=auto band=2ghz-onlyn basic-rates-a/g=\
    6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz \
    compression=no country=no_country_set default-ap-tx-limit=0 \
    default-authentication=yes default-client-tx-limit=0 default-forwarding=\
    yes disable-running-check=no disabled=no disconnect-timeout=3s distance=\
    dynamic frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower \
    frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
    s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
    cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
    3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 installation=any \
    interworking-profile=disabled keepalive-frames=enabled l2mtu=1600 \
    mac-address=4C:5E:0C:FB:A2:BF max-station-count=2007 mode=ap-bridge mtu=\
    1500 multicast-buffering=enabled multicast-helper=default name=wlan1 \
    noise-floor-threshold=default nv2-cell-radius=30 nv2-downlink-ratio=50 \
    nv2-mode=dynamic-downlink nv2-noise-floor-offset=default nv2-qos=default \
    nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" \
    on-fail-retry-time=100ms preamble-mode=both radio-name=4C5E0CFBA2BF \
    rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default \
    secondary-channel="" security-profile=default ssid=\
    station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled \
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 \
    tx-chains=0,1 tx-power-mode=default update-stats-interval=disabled \
    vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none \
    wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
    wireless-protocol=802.11 wmm-support=disabled wps-mode=push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
    bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:\
    17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H\
    T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-\
    7:17"
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=\
    0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" \
    smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none \
    !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=\
    default !parent-queue !queue-type shared-users=1 status-autorefresh=1m \
    transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048,modp1024 dpd-interval=2m \
    dpd-maximum-failures=5 enc-algorithm=aes-128,3des hash-algorithm=sha1 \
    lifetime=1d name=default nat-traversal=yes proposal-check=obey
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=\
    aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=\
    modp1024
add name=dhcp ranges=192.168.90.10-192.168.90.100
add address-pool=dhcp authoritative=yes bootp-support=static disabled=no \
    interface=bridge1 lease-script="" lease-time=10m name=dhcp1 use-radius=no
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
    stop-bits=1
/ppp profile
set *0 address-list="" !bridge !bridge-horizon !bridge-path-cost \
    !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout \
    !incoming-filter !insert-queue-before !interface-list !local-address \
    name=default on-down="" on-up="" only-one=default !outgoing-filter \
    !parent-queue !queue-type !rate-limit !remote-address !session-timeout \
    use-compression=default use-encryption=default use-mpls=default use-upnp=\
    default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon !bridge-path-cost \
    name=default-encryption on-down="" on-up="" only-one=default \
    !outgoing-filter !parent-queue !queue-type !rate-limit !remote-address \
    !session-timeout use-compression=default use-encryption=yes use-mpls=\
    default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
    pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
    pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
    pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
    pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
    pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
    pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set ether6 queue=only-hardware-queue
set ether7 queue=only-hardware-queue
set ether8 queue=only-hardware-queue
set ether9 queue=only-hardware-queue
set ether10 queue=only-hardware-queue
set sfp1 queue=only-hardware-queue
set wlan1 queue=wireless-default
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
    3200 framer-policy=none
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id \
    !confederation disabled=no ignore-as-path-len=no name=default out-filter=\
    "" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=\
    no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 \
    routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id \
    !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 \
    metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 \
    !mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
    !routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
    backbone type=default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5 \
    encryption-protocol=DES name=public read-access=yes security=none \
    write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000 \
    disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=\
    0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=\
    bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
    eb,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude" skin=\
    default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
    ssword,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude" skin=\
    default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
    winbox,password,web,sniff,sensitive,api,romon,dude,tikapp" skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled \
    mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path="" \
    require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=yes crl-store=system crl-use=yes
add auto-isolate=no bpdu-guard=no bridge=bridge1 broadcast-flood=yes \
    disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none \
    hw=yes ingress-filtering=no interface=ether1 internal-path-cost=10 learn=\
    auto multicast-router=temporary-query path-cost=10 point-to-point=auto \
    priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no \
    trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
    hw=yes ingress-filtering=no interface=ether2 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether3 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether4 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether5 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether6 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether7 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether8 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether9 internal-path-cost=10 learn=\
    hw=yes ingress-filtering=no interface=ether10 internal-path-cost=10 \
    learn=auto multicast-router=temporary-query path-cost=10 point-to-point=\
    auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no \
    tag-stacking=no trusted=no unknown-multicast-flood=yes \
    hw=yes ingress-filtering=no interface=sfp1 internal-path-cost=10 learn=\
    ingress-filtering=no interface=wlan1 internal-path-cost=10 learn=auto \
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
    use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes \
    tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=\
    1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
    udp-stream-timeout=3m udp-timeout=10s
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes \
    arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes \
    max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=\
    yes send-redirects=yes tcp-syncookies=no
/interface detect-internet
set detect-interface-list=none internet-interface-list=none \
    lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 \
    caller-id-type=ip-address default-profile=default-encryption enabled=no \
    keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited \
    mrru=disabled one-session-per-host=no use-ipsec=no
add disabled=no interface=lte1 list=WAN
add disabled=no interface=bridge1 list=LAN
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=\
    no keepalive-timeout=60 mac-address=FE:B9:0D:D1:05:70 max-mtu=1500 mode=\
    ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
    default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 \
    max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any \
    verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" \
    caps-man-names="" certificate=none discovery-interfaces="" enabled=no \
    interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
    no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.90.1/24 disabled=no interface=ether1 network=192.168.90.0
/ip cloud
set ddns-enabled=no ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.90.0/24 caps-manager="" dhcp-option="" dns-server="" \
    gateway=192.168.90.1 netmask=24 ntp-server="" wins-server=""
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
    max-concurrent-queries=100 max-concurrent-tcp-sessions=20 \
    max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s \
    servers=""
add action=drop chain=input !connection-bytes !connection-limit \
    !connection-mark !connection-nat-state !connection-rate !connection-state \
    !connection-type !content disabled=no !dscp !dst-address \
    !dst-address-list !dst-address-type !dst-limit !dst-port !fragment \
    !hotspot !icmp-options !in-bridge-port !in-bridge-port-list !in-interface \
    !in-interface-list !ingress-priority !ipsec-policy !ipv4-options \
    !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port \
    !out-bridge-port-list !out-interface !out-interface-list !packet-mark \
    !packet-size !per-connection-classifier !port !priority protocol=icmp \
    !psd !random !routing-mark !routing-table !src-address !src-address-list \
    !src-address-type !src-mac-address !src-port !tcp-flags !tcp-mss !time \
    !tls-host !ttl
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
add action=masquerade chain=srcnat disabled=no out-interface-list=WAN \
    !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" \
    disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=\
    all src-address=::/0 template=yes
/ip ipsec settings
set xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster \
    cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no \
    max-cache-object-size=2048KiB max-cache-size=unlimited \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no \
    src-address=::
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
    all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
    max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no \
    host-key-size=2048 strong-crypto=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=32k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes \
    dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes \
    igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes \
    ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=\
    yes nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=\
    yes packets=yes protocol=yes src-address=yes src-address-mask=yes \
    src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes \
    tcp-seq-num=yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no !forced-ip interface=bridge1 type=internal
add disabled=no !forced-ip interface=lte1 type=external
/lcd
set backlight-timeout=30m color-scheme=dark default-screen=main-menu enabled=\
    yes flip-screen=no read-only-mode=no time-interval=min touch-screen=\
    enabled
/lcd pin
set hide-pin-number=no pin-number=1234
/lcd interface
set wlan1 disabled=no max-speed=auto timeout=10s
set sfp1 disabled=no max-speed=auto timeout=10s
set ether1 disabled=no max-speed=auto timeout=10s
set ether2 disabled=no max-speed=auto timeout=10s
set ether3 disabled=no max-speed=auto timeout=10s
set ether4 disabled=no max-speed=auto timeout=10s
set ether5 disabled=no max-speed=auto timeout=10s
set ether6 disabled=no max-speed=auto timeout=10s
set ether7 disabled=no max-speed=auto timeout=10s
set ether8 disabled=no max-speed=auto timeout=10s
set ether9 disabled=no max-speed=auto timeout=10s
set ether10 disabled=no max-speed=auto timeout=10s
/lcd interface pages
set 0 interfaces=wlan1
/lcd screen
set 0 disabled=no timeout=10s
set 1 disabled=no timeout=10s
set 2 disabled=no timeout=10s
set 3 disabled=no timeout=10s
set 4 disabled=no timeout=10s
set 5 disabled=no timeout=10s
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no \
    use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
    multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public \
    trap-generators=temp-exception trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=Europe/Sofia
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system identity
set name=MikroTik
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
/system routerboard settings
set auto-upgrade=yes baud-rate=115200 boot-delay=2s boot-device=\
    nand-if-fail-then-ethernet boot-protocol=bootp enable-jumper-reset=yes \
    enter-setup-on=any-key force-backup-booter=no protected-routerboot=\
    disabled reformat-hold-button=20s reformat-hold-button-max=10m \
    silent-boot=no
/system routerboard usb
set usb-mode=automatic
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m ping-timeout=1m \
    watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any \
    filter-interface="" filter-ip-address="" filter-ip-protocol="" \
    filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" \
    filter-operator-between-entries=or filter-port="" filter-stream=no \
    memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=\
    no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=yes \
    stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
    use-radius=no
Functionality-wise all is working just fine! Those darn LTE speeds, though… :confused:
Same LTE modem is utilizing ~93% of the LTE cell speed when I’m using it with a laptop. I’ve chosen an excellent LTE cell @ 15MHz BW and stellar RSRP & SINR (I can monitor these from the network-side, PRB utilization too :slight_smile: ). More so, I’m also getting 90Mbps DL & 25Mbps UL with the same modem and a friggin’ TP-LINK!!! A TP-LINK FOR $20!!!
So, it’s not the LTE network, it’s not the modem itself. It should be something with the RB2011 or RouterOS.
Many moons ago, I created couple of tickets with MT support, to none of which I got a response to this day. They are so silent!
Can anyone please help me get decent LTE speeds out of ANY Tik with this E3372?
Hi zlobster,
I have exactly the same problem. Well, almost.
I have two Mikrotik RB3011, a VDSL2+ Modem and a business internet provider which wants a VLAN7 for his PPPoE Dialups.
When I connect my Notebook with the Modem, give it a VLAN7 and bring up the dialup I get a speed of 260 by 100 Mbit/s on “speedtest.net”. Now if I configure on of the Mikrotik RB3011s with a VLAN7, a PPPoE Dialup on that VLAN, a testing-LAN on eth2 and a masquerade of course for outgoing traffic, I’m locked to ~35Mbit/s in both directions.
I tested two different RB3011 with the delivered MikrotikOS 6.40.8 and also with up to 6.43.4. The CPU does not get over 2% load. There are no Queues configured. We tested all MTU’s which made PPPoE Dialup possible (below 1430 didn’t dial up, above 1510 didn’t dial as well) no difference, except it went down even a bit more with only 1430 MTU.
This is a huge problem. I will see if the Mikrotik Support responds to my query.
Hello Cat!
Thanks for your post! I’m pretty sure it’s a widespread issue. I’ve also tested with hAP ac, RB951 and a few others. The results are always the same.
More so, I also sourced 2 more, albeit a little different E3372’s. SSDD, basically. Modems work perfectly fine outside MikroTik devices, but not in those.
I’ve almost gave up at this point, and I’m trying to at least get the attention of some moderators, so my rant could be hopefully forwarded to someone willing to answer it. Hell, I don’t even want a solution now. I’d be happy with a simple “Yeah, our Tiks are kind of screwed when it comes to modems (among other things)…”, so at least I can invest in decent solution then.
Hi
Did this even become better for you?
What mode is the stick in?
thanks
I end up using a managed switch infront of my Tik when the ISP needs a VLAN Tag.
