I made a testing environment with 2x SXT LITE5.
Setup:
Distance ~4m.
I lowered the TX power.
Each SXT has a windows pc (win7 and
directly connected to it.
Results (pc to pc over a gbit switch):
C:\iperf>iperf -c 192.168.0.16 -w 256k -l 256k
Client connecting to 192.168.0.16, TCP port 5001
TCP window size: 256 KByte
[ 3] local 192.168.0.32 port 53372 connected with 192.168.0.16 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 1.07 GBytes 916 Mbits/sec
C:\iperf>iperf -c 192.168.0.16 -w 256k -l 256k -d
Server listening on TCP port 5001
[ 4] local 192.168.0.32 port 53477 connected with 192.168.0.16 port 5001
[ 5] local 192.168.0.32 port 5001 connected with 192.168.0.16 port 49394
[ 4] 0.0-10.0 sec 724 MBytes 607 Mbits/sec
[ 5] 0.0-10.1 sec 723 MBytes 600 Mbits/sec
Results over the SXT link:
SXT to SXT UDP bandwidth test yields ~98MBit each way and bi directional. TCP didn’t make sense cause it would peg the SXT cpu at 100%.
Iperf:
TCP window size: 64.0 KByte (default)
[ 3] local 192.168.0.32 port 51727 connected with 192.168.0.16 port 5001
[ 3] 0.0-10.0 sec 58.9 MBytes 49.2 Mbits/sec
C:\iperf>iperf -c 192.168.0.16 -d
[ 4] local 192.168.0.32 port 51871 connected with 192.168.0.16 port 5001
[ 5] local 192.168.0.32 port 5001 connected with 192.168.0.16 port 49387
[ 4] 0.0-10.0 sec 43.5 MBytes 36.4 Mbits/sec
[ 5] 0.0-10.1 sec 42.9 MBytes 35.5 Mbits/sec
Very low.
Weird thing is that file copy pc to pc over SXT yields better throughput:
I can get ~85Mbits in each direction, but full duplex only 53/53Mbits.
The SXT cpu is fine (~40% usage) and I have no idea what to do or how to test.
Mikrotik bandwidth test from PC to PC gives crap numbers, much lower than real tests or even iperf.
Any ideas what could be wrong?
