low troughput
buona sera a tutti.
Vi chiedo aiuto o consigli per risolvere un problema che non riesco a risolvere: Sulla mia rete ho 4 AP 1xNetbox5 1xNetmetal5 1xMantbox 1xshg5, tutte queste radio hanno lo stesso processore e lo stesso chipset radio. Ad ognuna di queste radio arrivo all’ interfaccia lan con un troughput di 500 mb circa,(risultato bandwitch test).Ai client collegati a questi ap invece non riesco ad arrivarci con piu’ di 50 mega nonostante dalla wireless table risultano collegati a 300mb in up e in dw. Gli mcs delle radio sono configurati di default e i segnali in rx sono intorno a -65 db. Qualcuno di voi puo’ darmi indicazioni per risolvere? In questo modo la massima velocita’ che ottengo con un client solo collegato e al massimo di 50 mega perdendo tutto il lavoro fatto per portare 500 mega agli ap.
Grazie mille
In English ? I will not use any translate for those who will ask..
thank’s Zacharias for your interest,
I ask you for help or advice to solve a problem that I can’t solve: On my network I have 4 AP 1xNetbox5 1xNetmetal5 1xMantbox 1xshg5, all these radios have the same processor and the same radio chipset. To each of these radios I arrive at the lan interface with a troughput of about 500 mb, (bandwitch test result). For the clients connected to these ap instead I can’t get there with more than 50 megs although from the wireless table they are connected to 300mb in up and in dw. The radio mcs are configured by default and the rx signals are around -65 db. Can any of you give me directions to solve? In this way the maximum speed that I get with a client only connected and at most 50 megs, losing all the work done to bring 500 megs to the ap.
Thanks so much
Your devices are connecting on 2.4 Ghz instead of 5 Ghz, thus lower speed.
Make sure your clients have 5 Ghz WiFi support and setup your MT APs accordingly.
Thought about replying in Latin, but being the start of a new year, I decided to play nice. (also, I suck at Latin)
hello inteq thank’s you for your answer
I try to answer in English
My ap are all in 5ghz. Mantbox, Netmetal and Netbox,and client are intested at 40mhz. but i dont work up 50 mb at 1,2 km long.
