This is likely a beginners question. I recently got a gigabit Internet, and after a quick research I bought the MikroTik RB4011iGS+RM router and hAP ac² access point. Long story short, I am getting between 200 - 300 MBit/s on the access point, and the upload speed is even lower while on my old Comcast router I was able to get 320 MBit/s likely maxing up my Internet speed. In wired mode, it’s all fine. I get 800 - 900 MBit/s both ways. I wonder if the hAP ac² is able to higher speeds to start with or if I need one of the multi-anthena access points supporting multiple streams. Is there a MikroTik product that would suite my needs? Or am I missing something else?
Just for a good measure, I did a factory reset, and selected WISP AP leaving everything on default, but I still can’t get higher than 300 Mbit/s download speeds. And I am I connected with no exception enabled now. However, I noticed that my upload speeds are actually not worse (anymore, or I misread it originally). They seem comparable, and sometimes even better. I believe I saw over 400 Mbit/s at one point. Still, overall I tend to get very variable results, and when running speed tests, the speed measurement seems to often stall and fluctuate. For reference, my computer is about 10 feet from the access point with nothing in-between.
It’s very puzzling. Now, I was able to get about 350 Mbit/s down and over 500 Mbit/s up. But it seems it was an exception. On the next measurement a second after, it was back to the usual values. Also, I completely turned off the old Comcast router just in case there was some interference or something like that.
– deleted accidental duplicate –
What channel width are you using?
I think by default it is set to 20/40. 20/40/80 XXXX may be worth a try if your client card supports an 80Mhz channel.
Please share your config: /export hide-sensitive file=anynameyoulike
In short: getting throughputs above 300 Mbps with your setup is pretty decent (but not great) result. Sure there are devices which do better (using similar hardware) and there are reports that wifiwave2 driver, which comes with ROSv7 (it’s testing software) enables much better performance on certain devices (unfortunately hAP ac² will likely not be supported by that driver).
hAP ac² features 2 spatial streams which, when used with 80 MHz channel, means maximum theoretical physical layer throughput of 866.7 Mbps (reference). Given that this number doesn’t account for duplex (wifi is half-duplex) nor for multiple access guard time, realistic max throughputs are quite a bit lower, so getting a bit more than half of theoretical maximum throughput is a good result. Then there are higher layer overheads (ethernet framing, IP headers, TCP headers), so application throughput gets even slightly lower. Typical test suites measure application throughput. Some add lower layer overhead, but the maths is not exact as actual overhead might be different from what application assumes. The rule of thumb is that realistic throughput is around one half of theoretical peak physical layer throughput.
If there’s any interference inside used frequency band (and wifi devices are usually not very good at measuring and showing it), then the physical layer throughput drops … either because transmitter has to pause for interference to stop or because transmitter has to use more robust (and slower) transmission modes to beat interference. And having both devices 10 feet apart with direct LOS doesn’t cancel the interference, it only helps to make interference effects smaller (and it mostly helps with the second cause mentioned, but not so much with the first cause mentioned).
Surely enough marketing specifications declare this device to be AC1200 device and number implies it should be capable of transfer speeds of 1200Mbps … but this declaration contains a lot of BS (as do all marketing figures without exceptions). For starters it sums up throughputs of two independent radio interfaces, normal clients can only use one of them. And second, it sums up theoretical maximum physical layer throughputs and then rounds the sum up (actual theoretical maximum physical layer throughputs are 300Mbps for 2.4 GHz part and 866.7Mbps for 5GHz part, so the actual sum is 1166.7Mbps, not 1200Mbps).
It does. I am using a regular MacBook Pro, a 2019 model.
Sometimes, it connects to a 80 Mhz channel, sometimes to 40 Mhz. Otherwise, my RSSI and noise values seem to be within the usual ranges (based on a quick Google search). RSSI is usually between -50 and -40 dBm and noise is between -100 and -90 dBm. Also, it always connects using 2 streams.
Thank you for the detailed response, mkx.
I was already aware of some of the limitations, but given the specs of the device, I expected speeds close to 400 Mbps. But more importantly, I am more worried about the speed fluctuations. Especially, given the Comcast box seems to be super consistent, and it’s clearly limited by the speed of my Comcast connection. I believe my Comcast router is the the xFi Advanced Gateway (XB6), if it rings any bell (https://www.xfinity.com/support/articles/broadband-gateways-userguides).
Long story short, I want to make use of my new Gigabit Internet (Ziply Fiber). Should I get another device? I had a quick look around, and it looks like there are two options from MikroTik: hAP ac³ or RB4011iGS+5HacQ2HnD-IN. I think the hAP ac³ looks a bit too similar to the hAP ac² (same max data rate and also only two spatial streams), and the RB4011iGS+5HacQ2HnD-IN seems like overkill. Is there any other good option in-between? I was originally looking at Ubiquiti, but I could not really find any that would fit my needs. I just want an access point I can put on my desk or in a shelf. I don’t need or want the hassle of mounting it to a wall or to a ceiling, and most Ubiquiti access points are mountable and they require PoE.
My config:
# sep/17/2021 00:36:39 by RouterOS 6.47.9
# software id = Q0WM-P7EI
# model = RBD52G-5HacD2HnD
# serial number = CDFC0EBEF87B
add admin-mac=2C:C8:1B:96:77:01 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country="united states" disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=MikroTik-967705 \
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country="united states" disabled=no distance=indoors \
frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-967706 \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/system clock
set time-zone-name=America/Los_Angeles
/tool mac-server
/tool mac-server mac-winbox
People who did test the upcoming wifiwave2 driver, confirmed that it both increases obtainable throughput as well as reduces throughput fluctuations. Which is something to look forward, however there’s no published ETA for ROS v7.1. It seems very likely that hAP ac3 will be supported, RB4011 (wireless version) as well. Currently there’s limitation that only single wireless driver can run in device. RB4011 (wireless version) has two distinct wireless chips and wifiwave2 driver doesn’t support the 2.4GHz one, so running wifiwave2 driver on RB4011 currently means having only 5GHz WiFi.
There’s another possibility: audience. It’s got superb radio hardware and both wifi chips are supported by same driver meaning that running ROS v7.1RC with wifiwave2 driver really makes device shine. MSRP places it right in between hAP ac3 and RB4011 ![]()
mkx, the op has an hapac2, why discuss hapac3 and rb4011.
so I will talk about tplink eap245 that works well for wifi5 for 5 years!
or tplink 660hd which blows audience out of the water
OP wrote in OP:
Audience with stable ROS v7 (with wifiwave2 driver) would quite probably satisfy the needs and is a Mikrotik product. None of TPlinks you’re mentioning answer the question in the second part of quoted text.
Being optimist I believe it’s just the matter of time to see stable ROS v7 happen. ![]()
Do note that Audience with current firmware won’t be any faster. It may even be slower. The Mikrotik drivers for the QCA9984 appear to be pretty poor. I get just over 200Mbps with two units in the same room.
The wifiwave2 drivers are quite limited at the moment. No bridging.
Often people have expectations and their purchases do not match expectations.
What is written in the quotes should not be derived as accurate until one understands
a. the true expectations
b. the full requirements.
Communication is not making assumptions it drilling down to the truth.
~300mbps is good for Mikrotik WiFi, if you need something faster there are other vendors out there with more innovative technologies like WiFi 6 and 4x4 UL/DL MU-MIMO as well as OFDMA.
Mkx
I have an Audience running that wifi driver.
Best through put I have seen from a Tik WAP.
However, it’s Buggy as S–t. The driver sometimes locks up the radio into searching for channel.
Can’t see how to tag VLANs.
Adding VAPs cause the radio to lock up too.
Doesn’t work with caps-man
Etc
Etc
Etc
It’s still getting clobbered by a Ruckus R510 I got in 2016.
And now an r510 is barely more money than an Audience. The ruckus doesn’t have the bugs… As it’s so mature… It’s end of sale.
Mikrotik and WiFi6??? Yeah… Not holding my breath on that one.
Original Poster…
Keep the 4011. Use it as a router. But get you wireless from someone else.
I know that currently ROS v7 is RC (with quality somewhere in between alpha and beta) and wifiwave2 driver quality is on the same level. But I wrote:
People who did test the upcoming wifiwave2 driver, confirmed that it both increases obtainable throughput as well as reduces throughput fluctuations. Which is something to look forward, however > there’s no published ETA for ROS v7.1> .
and
Audience with > stable ROS v7 > (with wifiwave2 driver) would quite probably satisfy the needs and is a Mikrotik product.
So I never wrote audience at this time is a stable and fast product, I wrote that it is an interesting product which has prospects of becoming viable solution. You’re welcome to express your doubts about feasibility of this solution to OP, but why are you picking on my own opinion? Many of us know your frustrations about Mikrotik’s wireless offerings in general and audience in particular …
Mkx
It wasn’t meant to pick on you or dismantle your view.
You stated that an Audience might satisfy the OP.
I was just listing why it is not suitable for anything beyond beta testing, at this point.
And I don’t think the author of the Original Post opened with “I wanna be an unpaid Beta Tester.” He wanted to know why his system wouldn’t do better than the ISP gear.
And on it’s best day… Current hardware is never gonna come close to what he was hoping for.
To be honest… I don’t condone all this “accepting” and “making excuses” for Mikrotik wifi.
If someone had told me flat out… “It doesn’t support wifi 5 properly. ACv2 is not in the foreseeable future.”
And Mikrotik support had just told me the truth when I was having so many problems…
I would have just skipped Mikrotik wifi.
Instead… I wasted thousands of hours trying to “fix” something I couldn’t. And a lot of clients lost faith in our company, over the problems the Tik WAPs introduced. We lost clients over it. And we went into our own pockets to replace a lot of units, to save relationships.
True words.
