Hi Guys,
We have a VERY short link e.g. 500 metres but are using 29dB antennas due to the dual-pol and tight signal. We are wanting to turn the Tx power down very low, what is the lowest setting we can use on Mikrotik with R52’s ?
Hi Guys,
Possibly down to -30 according to CLI.
TxPower ::= [-]Num
Num ::= -30..30 (integer number)
YMMV, play with it and let us know.
-Louis
Thanks, will try it ASAP and let you all know.
I don’t think it goes below 5 dBm or maybe even a bit higher.
This issue was discussed just a few days ago: http://forum.mikrotik.com/t/close-p2p-links-tx-power-settings/20801/1
Think 13…
