I would like to put an R11e-LR9 and R11e-LR2 in a single LtAP device, in order to get 900 MHz and 2.4 GHz LORA coverage in one go. Is this a supported configuration within RouterOS? Has anyone tried this, and what are the possible hurdles to overcome?
It should works.
If you have some troubles to get both working at same time probably here you can find some useful tip.
Regards.
