LtAP 4G kit breaks SIM cards
I have no previous experience with Mikrotik devices, however when I was looking for a cheap and flexible solution for a 4G backup connection at work, I came across the LtAP 4G kit. I bought one and it worked perfectly… Until the device lost internet connectivity. The logs displayed messages like:
sent AT+CPIN?
rcvd +CME ERROR: SIM failure
I have tried rebooting the device, re-inserting the sim card, and swapping sim card slots but nothing worked. On a hunch, I tested the sim card in my phone and it turns out it wasn’t working in there either. I had a spare SIM card lying around, activated the thing and inserted it into the LtAP 4G. Problem solved. Until a few weeks later… same issue. Internet connection lost, tried all the usual troubleshooting steps but the SIM card was broken again. (The SIM card didn’t work in my phone and neither did it work in a Netgear mobile router.)
So this time I got a brand spanking new SIM card directly from the telco. Problem solved. Until a few weeks later… same issue. Rinse and repeat.
Is this a known issue with Mikrotik LTE devices? What can I do to stop the LtAP from breaking SIM cards?
Kind regards,
Thomas
EDIT:
Here’s an output of the log file:
16:15:45 lte,async lte1: sent ATE0
16:15:45 lte,async lte1: rcvd OK
16:15:45 lte,async lte1: sent AT+CGMI
16:15:45 lte,async lte1: rcvd +CGMI: "MikroTik"
16:15:45 lte,async lte1: sent AT+CGMM
16:15:45 lte,async lte1: rcvd +CGMM: "R11e-LTE6"
16:15:45 lte,async lte1: sent AT+CGMR
16:15:45 lte,async lte1: rcvd R11e-LTE6_V020
16:15:45 lte,async lte1: sent AT+CGSN
16:15:45 lte,async lte1: rcvd 356662100149621
16:15:45 lte,async lte1: sent AT+CFUN?
16:15:45 lte,async lte1: rcvd +CFUN: 4
16:15:45 lte,async lte1: sent AT+CMEE=2
16:15:45 lte,async lte1: sent AT+CREG=2
16:15:45 lte,async lte1: sent AT+CGREG=2
16:15:45 lte,async lte1: sent AT+CEREG=2
16:15:45 lte,async lte1: sent AT+CGEREP=2,0
16:15:45 lte,async lte1: sent AT+CMGF=0
16:15:45 lte,async lte1: sent AT+CNMI=1,1,0,1,0
16:15:45 lte,async lte1: sent AT+EEMOPT=1
16:15:46 lte,async lte1: rcvd OK
16:15:46 lte,async lte1: sent AT*MRD_SN?
16:15:46 lte,async lte1: rcvd *MRD_SN:AE390380C01D
16:15:46 lte,async lte1: sent AT+CPIN?
16:15:46 lte,async lte1: rcvd +CME ERROR: SIM failure
16:15:46 lte,async,event *ICCID: 00000000000000000000
16:15:46 lte,async,event *EUICC: 0
16:15:46 lte,async,event +CPIN: SIM CRASH
16:15:46 lte,async,event *EUICC: 4
16:15:46 lte,async,event +CPIN: SIM REMOVED
16:15:47 lte,async,raw +CREG: 0
16:15:47 lte,async,raw $CREG: 0
16:15:47 lte,async,raw +CGREG: 0
16:15:47 lte,async,raw +CEREG: 0
16:15:48 lte,async lte1: sent AT+CPIN?
16:15:48 lte,async lte1: rcvd +CME ERROR: SIM not inserted
16:15:50 lte,async lte1: sent AT+CPIN?
16:15:50 lte,async lte1: rcvd +CME ERROR: SIM not inserted
16:15:50 lte,async,event *RADIOPOWER: 0
16:15:50 lte,async,event *ICCID: 00000000000000000000
16:15:50 lte,async,event *EUICC: 0
16:15:50 lte,async,event +CPIN: SIM CRASH
16:15:50 lte,async,event *EUICC: 4
16:15:50 lte,async,event +CPIN: SIM REMOVED
16:15:52 lte,async lte1: sent AT+CPIN?
16:15:52 lte,async lte1: rcvd +CME ERROR: SIM not inserted
16:15:54 lte,async lte1: sent AT+CPIN?
This happens if I switch the SIM card from one slot to another (to force a re-initialization).
RMA. I had a LtAP LTE kit with a broken SIM port also, but the difference is that the broken thing was the SIM port, not SIM cards.
Regards.
RMA, and update the LTE card’s firmware this time. It’s hard to say whether that was the cause, but best practice is to keep everything up to date. I’ve been using an LtAP LTE6 kit for a few months now without issue. Be gentle when you insert the SIM card as others have posted photographs of broken SIM ports.
