LtAP Dual SIM Setup
Hi guys, can you please enlighten me as to how to setup Dual SIM on the LtAP? I would like to insert two SIMs from two different mobile providers and then if the main SIM (Sim Slot 1) loses connection then it should automatically connect using SIM 2 (Sim Slot 2).
What would I need to do to make it work like mentioned above?
https://wiki.mikrotik.com/wiki/Dual_SIM_Application
how can i make it with WINBOX instead of command line?
thk
You can paste that script in System - Scripts menu also in Winbox. Just read the commands that are specifed, and click on appropriate menus in Winbox.
other clarification please .. I have two sims and I have created two APNs. how can I tell SXT “use APN1 for SIM # 1 and APN2 for SIM # 2”?
I read wiki https://wiki.mikrotik.com/wiki/Dual_SIM_Application but I do not think there is an explanation for my request. can you help me?
Add APN profile selection line together with changing SIM slot line:
/interface lte set lte1 apn-profiles=...
i have two sim in SXT now..and two different APn profiles
now, i’m trying to learn line command from terminal…
if i write …" /interface lte info" the system reply to me..“number”
which is the right answer?
(telephon number?..IMEI?..ICCD? or what?)
thk
