LTAP LTE6 kit - board removal
Does anybody have any tips on getting the board out of the ltap case to access the pci modem in the slot on the bottom please? I’ve removed all the screws I can see but it doesn’t want to budge (and I don’t want to force it).
Is there a hidden screw somewhere? Or perhaps a clip?
Thanks!
W.
Removing the screws is enough. Then lift the plastic cover carefully,
Regards.
