With which CLI command could I get the serial number of the LTE card in the LtAP mini and LHGG devices?
/interface lte info lte1
CLI command doesn’t give this information.
System → resources → USB
Thank you for your answer, but that’s not what I want.
This is the result your command:
/system resource usb> print
# DEVICE VENDOR NAME SPEED
0 1-0 Linux 3.3.5 ehci_hcd RB400 EHCI 480
1 1-1 MikroTik R11e-LTE 480
I would need the serial number of the LTE module
Print detailed
/system resource usb print detail
Regards.
Thanks, I’ll try it next week.
Unfortunately this command also can’t show the real serial numbers… ![]()
0 device="1-0" vendor="Linux 3.3.5 ehci_hcd" name="RB400 EHCI"
serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0002"
speed="480" ports=1 usb-version=" 2.00"
1 device="1-1" vendor="MikroTik" name="R11e-LTE" serial-number="000000000000"
vendor-id="0x2cd2" device-id="0x0001" speed="480" usb-version=" 2.00"
Probably you need open a ticket on official Mikrotik support. Most probably is a RouterOS bug.
Regards.
Have you tried upgrading the firmware on the modem (in the LTE interface)? Does it have a valid IMEI number in the LTE interface?
I recall see 0000 when the firmware upgrade fails on some of the r11e-LTE things… So a support ticket seem reasonable, just make sure to generate a supout.rif and provide that when you open a ticket.
