Software and firmware 6.42.5, fresh default configuration. What I do:
/system console disable 0
/system gps set port=serial0 enabled=yes
Resulting in:
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1
/port firmware
set directory=firmware ignore-directip-modem=no
/system gps
set channel=0 enabled=yes gps-antenna-select=internal init-string="" port=serial0 set-system-time=no
If I set GPS logging, I see GPS data running. The only change I see is that date changes from Nov/30/1999 00:00:00 to Jan/06/1980 00:02:30 (GPS start era).
Jul/04/2018 21:47:25 gps,raw GPS:: $GPGGA,001014.020,0,0,M,M,4E
Jul/04/2018 21:47:25 gps,raw GPS:: $GPGLL,001014.020,V,N7C
Jul/04/2018 21:47:25 gps,raw GPS:: $GPGSA,A,1,1E
Jul/04/2018 21:47:25 gps,raw GPS:: $GPGSV,1,1,0079
Jul/04/2018 21:47:25 gps,raw GPS:: $GPRMC,001014.020,V,0.00,0.00,060180,N44
Jul/04/2018 21:47:25 gps,raw GPS:: $GPVTG,0.00,T,M,0.00,N,0.00,K,N32
Jul/04/2018 21:47:26 gps,raw GPS:: $GPGGA,001015.020,0,0,M,M,4F
Jul/04/2018 21:47:26 gps,raw GPS:: $GPGLL,001015.020,V,N7D
Jul/04/2018 21:47:26 gps,raw GPS:: $GPGSA,A,1,1E
Jul/04/2018 21:47:26 gps,raw GPS:: $GPGSV,1,1,0079
Jul/04/2018 21:47:26 gps,raw GPS:: $GPRMC,001015.020,V,0.00,0.00,060180,N45
Jul/04/2018 21:47:26 gps,raw GPS:: $GPVTG,0.00,T,M,0.00,N,0.00,K,N32
Jul/04/2018 21:47:27 gps,raw GPS:: $GPGGA,001016.020,0,0,M,M,4C
Jul/04/2018 21:47:27 gps,raw GPS:: $GPGLL,001016.020,V,N7E
Jul/04/2018 21:47:27 gps,raw GPS:: $GPGSA,A,1,1E
Jul/04/2018 21:47:27 gps,raw GPS:: $GPGSV,1,1,0079
Jul/04/2018 21:47:27 gps,raw GPS:: $GPRMC,001016.020,V,0.00,0.00,060180,N46
Jul/04/2018 21:47:27 gps,raw GPS:: $GPVTG,0.00,T,M,0.00,N,0.00,K,N32
Am I missing smth?
With mAP 2nd + BU-353S4 USB GPS module I’m able to get location fixed literary in seconds.
