LtAP mini LTE (EC200A) + Vodafone PNG – Registers but no IP / stuck on 3G
LtAP mini LTE (RB912R-2nD-LTm, Quectel EC200A), RouterOS 7.20.8, Vodafone PNG SIM.
Registers successfully (Vodafone PNG, LAC 10, Cell ID 21021)
Registration Status: registered, PIN Status: ok
APN set to "internet" (official Vodafone PNG APN)
Network Mode forced to LTE only (gsm + 3g unchecked)
Tried multiple Modem Init strings (AT+CGDCONT, etc.)
Result: Stays on 3G (HSDPA/HSUPA), no IP address assigned to lte1 / VF PNG interface.
Has anyone successfully run EC200A-based MikroTik on Vodafone PNG with working LTE data session?
Any working AT commands, band locking, or APN tricks appreciated.
Thanks.
Check on command line that you have actually set use-network-apn=no, there have been some cases where (possibly some kind of misalignment between GUI and CLI) the APN has been set but use-network-apn remained at yes (default).
Use in terminal the command:
/interface lte apn export
you should get something like:
/interface lte apn
set [ find default=yes ] use-network-apn=no
add apn=internet name=internet
Thanks for the suggestion.
I ran:
text
Output:
text
/interface lte apn
set [ find default=yes ] comment=Vodafone-png name="VF PNG" use-network-apn=no
So use-network-apn=no is already set correctly.
Additional details about the network:
  • Operator: Vodafone PNG (prepaid DATA SIM VF260326 8559216 81528013)
  • Official APN: internet
  • Network bands: 4G uses B3 (1800 MHz) and B28 (700 MHz); 3G uses B1 (2100 MHz)
  • The same SIM works immediately in a ZLT-P11/P10+ router, but on the RB912R-2nD + EC200A-EU it registers (PIN ok) but stays mostly deregistered with no IP assigned.
  • Current RouterOS: 7.22.1 stable
  • Tried LTE-only mode, multiple disable/enable cycles, and various modem-init strings (including AT+CGDCONT=1,"IP","internet";AT+CGATT=1) with no success.
Any other ideas for this specific combination (EC200A-EU + Vodafone PNG)? Especially anything related to band locking, PDP context activation, or known quirks with this modem on PNG networks.
Thanks in advance.
You do have the apn set, like:
/interface lte apn
right?
I think you should open a support ticket, since the settings are correct and the SIM does work on another device.
  1. You need to try a SIM card from a different operator.
  2. The AT&F0 command is used on the Quectel EC200A series to restore factory default settings.
    So, you can try
    /interface lte at-chat lte1 input="AT&F0”
  3. Try to make factory reset Mikrotik.
Thanks for the follow-up.
Yes, the APN is set correctly:
text
/interface lte apn
The same SIM works immediately in another device, so the settings appear correct, but the EC200A still stays mostly deregistered with no IP.
I will open a support ticket with MikroTik as you suggested.
Thanks again for your help.
Well, this snippet doesn't show it as set:
this is why I asked.
You should see also a line like:
Here is the full current output of /interface lte apn export:
text
/interface lte apn
There is no separate add apn=internet name=internet line.
Is this what you expected, or should I manually add the "internet" APN entry?
Thanks again.
It will be much easier for you to setup everything in WinBox.
Yes, in Winbox (GUI) it would be easier, you fill the APN: field AND uncheck the "Use Network APN" checkbox.
See here as an example:
Then check the whole settings with:
/interface/lte/apn/print detail
Thanks for the additional suggestions.
  1. I have now tested with a Digicel PNG SIM in the top slot. It is detected correctly (different IMSI/ICCID shown), but it also stays deregistered with no IP address. Both the Vodafone PNG and Digicel PNG SIMs work immediately when inserted in other devices.
  2. I ran the AT&F0 command:
text
/interface lte at-chat [find name="VF PNG"] input="AT&F0"
It returned OK. I then restarted the interface, but the status is still deregistered.
  1. I would prefer to avoid a full factory reset of the router if possible, as I had major trouble regaining access after previous resets.
I have also opened a support ticket with MikroTik and attached the supout.rif with LTE logging enabled.
Here is the output of /interface lte apn print detail:
text
Flags: * - DEFAULT
 0 * ;;; Vodafone-png
     name="Digicel" apn="internet.digicelpng.com" use-peer-dns=yes use-network-apn=no
     add-default-route=yes default-route-distance=2 ip-type=auto authentication=none
I also manually set the default APN back to "VF PNG" with use-network-apn=no.
I have tested with a Digicel PNG SIM in the top slot. It is detected (different IMSI/ICCID), but it also stays deregistered with no IP.
Both the Vodafone and Digicel SIMs work immediately in other devices.
I have opened a support ticket with MikroTik and attached the supout.rif with LTE logging enabled.
Any other ideas or suggestions are welcome.
Thanks again.
set apn to “internet”
