Frrr
1
Can’t reset device (LtAP mini LTE kit 2024) with reset button. Exhausted all options… This also: https://help.mikrotik.com/docs/display/ROS/Reset+Button
Need help.
Device wasn’t upgraded, recently was bought, there was mistake in configuration and it is in inaccessible state.
jaclaz
2
Have you tried with Winbox connecting by MAC address?
If the normal reset procedure does not work and the device is not seen by Winbox, there is still the serial port, see:
http://forum.mikrotik.com/t/ltap-mini-lte-factory-reset/138839/1
http://forum.mikrotik.com/t/firewall-locked-out-myself-what-was-the-reason/139018/1
(references are for the older version, but the procedure should have remained the same).
