LtAP mini LTE kit - simultaneous Poe and DC power supply ?
hello, I have LtAP mini LTE kit, can I use Poe and DC power at the same time? for example DC = 14v and PoE = 24 - to have one active always in case of failure of one.
Can I use a voltage lower than 12v for Poe?
The photos of the product in the store have different power values ​​than mine, i.e. mine has DC = 8-30 and Poe = 12-57 and the photo shows similar values ​​for both inputs.
i found the answer - https://youtu.be/BkZHRD6svQU?t=2876
thank you Mr. Andis Āriņš
Answer is Yes you can :slight_smile: it will work as failover
