Ltap mini LTE kit + telia.ee SIM - no roaming, how to debug?
Hi!
I have Ltap mini LTE kit with external antenna. I use a SIM from telia.ee, roaming allowed by device an by SIM contract. Set works fine until I was in estonia.
In Latvia and Lithuania I can not get registered into operator network.
Do you can suggest from where to start debugging?
Typical LTE log, no matter what I have changed is following:
 108	Jul/18/2022 11:20:10	memory	lte, async	lte1: sent AT E0 V1
109	Jul/18/2022 11:20:10	memory	lte, async	lte1: rcvd OK
110	Jul/18/2022 11:20:10	memory	lte, async	lte1: sent AT+CFUN?
111	Jul/18/2022 11:20:10	memory	lte, async	lte1: rcvd +CFUN: 1
112	Jul/18/2022 11:20:10	memory	lte, async	lte1: sent AT+CFUN=4
113	Jul/18/2022 11:20:11	memory	lte, async, event	lte1: ^SRVST: 0
114	Jul/18/2022 11:20:11	memory	lte, async, raw	lte1: +CREG: 0
115	Jul/18/2022 11:20:11	memory	lte, async, raw	lte1: +CEREG: 0
116	Jul/18/2022 11:20:11	memory	lte, async, event	lte1: +CGEV: ME DETACH
117	Jul/18/2022 11:20:11	memory	lte, async	lte1: rcvd OK
118	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CFUN?
119	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd +CFUN: 4
120	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CMEE=2
121	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
122	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CREG=2
123	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
124	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CGREG=2
125	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
126	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CEREG=2
127	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
128	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CGEREP=2,0
129	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
130	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CMGF=0
131	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
132	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CNMI=1,1,0,1,0
133	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
134	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+EEMOPT=1
135	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
136	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT*MRD_SN?
137	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd *MRD_SN:xxxxxxxx
138	Jul/18/2022 11:20:12	memory	lte, debug	lte1: serial: *MRD_SN:xxxxxxxxx
139	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CFUN=4
140	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
141	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT*CGDFLT=0,"IP","Internet",,,,,,,,,,1,0,,,,,,,1
142	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
143	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT*CGDFAUTH=0,0
144	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd OK
145	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CPIN?
146	Jul/18/2022 11:20:12	memory	lte, async	lte1: rcvd +CPIN: SIM PIN
147	Jul/18/2022 11:20:12	memory	lte, async	lte1: sent AT+CPIN="xxxxx"
148	Jul/18/2022 11:20:13	memory	lte, async	lte1: rcvd OK
149	Jul/18/2022 11:20:13	memory	lte, async	lte1: sent AT+CFUN?
150	Jul/18/2022 11:20:14	memory	lte, async, event	lte1: +CPIN: READY
151	Jul/18/2022 11:20:14	memory	lte, async, event	lte1: ^SIMST: 1
152	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd +CFUN: 4
153	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CMEE=2
154	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
155	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CREG=2
156	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
157	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CGREG=2
158	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
159	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CEREG=2
160	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
161	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CGEREP=2,0
162	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
163	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CMGF=0
164	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
165	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CNMI=1,1,0,1,0
166	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
167	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+EEMOPT=1
168	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
169	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT*MRD_SN?
170	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd *MRD_SN:xxxxxxx
171	Jul/18/2022 11:20:14	memory	lte, debug	lte1: serial: *MRD_SN:xxxxxxxx
172	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CFUN=4
173	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
174	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT*CGDFLT=0,"IP","Internet",,,,,,,,,,1,0,,,,,,,1
175	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
176	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT*CGDFAUTH=0,0
177	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd OK
178	Jul/18/2022 11:20:14	memory	lte, async	lte1: sent AT+CPIN?
179	Jul/18/2022 11:20:14	memory	lte, async	lte1: rcvd +CPIN: READY
180	Jul/18/2022 11:20:15	memory	lte, async, event	lte1: +MMSG: 2, 0
181	Jul/18/2022 11:20:15	memory	lte, async, event	lte1: +MMSG: 3, 1
182	Jul/18/2022 11:20:15	memory	lte, async, event	lte1: ^SMMEMFULL: SM
183	Jul/18/2022 11:20:15	memory	lte, async, event	lte1: +MPBK: 1
184	Jul/18/2022 11:20:15	memory	lte, async, event	lte1: +MMSG: 0, 1
185	Jul/18/2022 11:20:15	memory	lte, async, event	lte1: ^SMMEMFULL: SM
186	Jul/18/2022 11:20:18	memory	lte, async	lte1: sent AT+CPMS="SM","SM","SM"
187	Jul/18/2022 11:20:18	memory	lte, async	lte1: rcvd +CPMS: 20,20,20,20,0,0
188	Jul/18/2022 11:20:18	memory	lte, async	lte1: sent AT+CFUN?
189	Jul/18/2022 11:20:18	memory	lte, async, event	lte1: +MMSG: 0, 1
190	Jul/18/2022 11:20:18	memory	lte, async, event	lte1: ^SMMEMFULL: SM
191	Jul/18/2022 11:20:18	memory	lte, async	lte1: rcvd +CFUN: 4
192	Jul/18/2022 11:20:18	memory	lte, async	lte1: sent AT+ICCID?
193	Jul/18/2022 11:20:18	memory	lte, async	lte1: rcvd +ICCID: xxxxxxxxxx
194	Jul/18/2022 11:20:18	memory	lte, async	lte1: sent AT+CNUM
195	Jul/18/2022 11:20:18	memory	lte, async	lte1: rcvd +CME ERROR: 100
196	Jul/18/2022 11:20:18	memory	lte, async	lte1: sent AT+CIMI
197	Jul/18/2022 11:20:19	memory	lte, async	lte1: rcvd xxxxxxxxxxxxxc
198	Jul/18/2022 11:20:19	memory	lte, async	lte1: sent AT+CPIN?
199	Jul/18/2022 11:20:19	memory	lte, async	lte1: rcvd +CPIN: READY
200	Jul/18/2022 11:20:19	memory	lte, async	lte1: sent AT*BAND=15,78,147,160,524487,1,2,0
201	Jul/18/2022 11:20:19	memory	lte, async	lte1: rcvd OK
202	Jul/18/2022 11:20:20	memory	lte, async	lte1: sent AT+COPS=0
203	Jul/18/2022 11:20:20	memory	lte, async	lte1: rcvd OK
204	Jul/18/2022 11:20:20	memory	lte, async	lte1: sent AT+CFUN=1
205	Jul/18/2022 11:20:20	memory	lte, async, raw	lte1: +CREG: 2
206	Jul/18/2022 11:20:20	memory	lte, async, raw	lte1: +CEREG: 2
207	Jul/18/2022 11:20:20	memory	lte, async	lte1: rcvd OK
208	Jul/18/2022 11:20:20	memory	lte, async	lte1: sent AT+COPS=3,0
209	Jul/18/2022 11:20:20	memory	lte, async	lte1: rcvd OK
210	Jul/18/2022 11:20:20	memory	lte, debug	lte1: config ok
211	Jul/18/2022 11:20:20	memory	lte, async, raw	lte1: sent AT+CFUN?
212	Jul/18/2022 11:20:20	memory	lte, async, raw	lte1: rcvd +CFUN: 1
213	Jul/18/2022 11:20:20	memory	lte, async, raw	lte1: sent AT+CSQ
214	Jul/18/2022 11:20:20	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
215	Jul/18/2022 11:20:23	memory	lte, async, raw	lte1: sent AT+CSQ
216	Jul/18/2022 11:20:23	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
217	Jul/18/2022 11:20:26	memory	lte, async, raw	lte1: sent AT+CSQ
218	Jul/18/2022 11:20:26	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
219	Jul/18/2022 11:20:29	memory	lte, async, raw	lte1: sent AT+CSQ
220	Jul/18/2022 11:20:29	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
221	Jul/18/2022 11:20:32	memory	lte, async, raw	lte1: sent AT+CSQ
222	Jul/18/2022 11:20:32	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
223	Jul/18/2022 11:20:35	memory	lte, async, raw	lte1: sent AT+CSQ
224	Jul/18/2022 11:20:35	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
225	Jul/18/2022 11:20:38	memory	lte, async, raw	lte1: sent AT+CSQ
226	Jul/18/2022 11:20:38	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
227	Jul/18/2022 11:20:41	memory	lte, async, raw	lte1: sent AT+CSQ
228	Jul/18/2022 11:20:41	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
229	Jul/18/2022 11:20:44	memory	lte, async, raw	lte1: sent AT+CSQ
230	Jul/18/2022 11:20:44	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
231	Jul/18/2022 11:20:47	memory	lte, async, raw	lte1: sent AT+CSQ
232	Jul/18/2022 11:20:47	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
234	Jul/18/2022 11:20:50	memory	lte, async, raw	lte1: sent AT+CSQ
235	Jul/18/2022 11:20:50	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
236	Jul/18/2022 11:20:53	memory	lte, async, raw	lte1: sent AT+CSQ
237	Jul/18/2022 11:20:53	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
238	Jul/18/2022 11:20:56	memory	lte, async, raw	lte1: sent AT+CSQ
239	Jul/18/2022 11:20:56	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
240	Jul/18/2022 11:20:59	memory	lte, async, raw	lte1: sent AT+CSQ
241	Jul/18/2022 11:20:59	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
242	Jul/18/2022 11:21:02	memory	lte, async, raw	lte1: sent AT+CSQ
243	Jul/18/2022 11:21:02	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
244	Jul/18/2022 11:21:05	memory	lte, async, raw	lte1: sent AT+CSQ
245	Jul/18/2022 11:21:05	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
246	Jul/18/2022 11:21:08	memory	lte, async, raw	lte1: sent AT+CSQ
247	Jul/18/2022 11:21:08	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
249	Jul/18/2022 11:21:11	memory	lte, async, raw	lte1: sent AT+CSQ
250	Jul/18/2022 11:21:11	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
251	Jul/18/2022 11:21:14	memory	lte, async, raw	lte1: sent AT+CSQ
252	Jul/18/2022 11:21:14	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
253	Jul/18/2022 11:21:17	memory	lte, async, raw	lte1: sent AT+CSQ
254	Jul/18/2022 11:21:17	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
255	Jul/18/2022 11:21:20	memory	lte, async, raw	lte1: sent AT+CSQ
256	Jul/18/2022 11:21:20	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
257	Jul/18/2022 11:21:23	memory	lte, async, raw	lte1: sent AT+CSQ
258	Jul/18/2022 11:21:23	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
259	Jul/18/2022 11:21:26	memory	lte, async, raw	lte1: sent AT+CSQ
260	Jul/18/2022 11:21:26	memory	lte, async, raw	lte1: rcvd +CSQ: 99,99
261	Jul/18/2022 11:21:29	memory	lte, async, raw	lte1: sent AT+CSQ
Thanks for any support or idea
Now in Latvia I can registered to operator network - to be disconnected immediately. Only new LTE log error is:
“+ CME Error: 100”
Which means “unknown” - according the “3GPP TS 27.007 V13.4.0 (2016-03)”
Most likely the APN is incorrectly specified. Usually wrong APN will work in home network, but not while roaming.
Try internet.tele2.ee or mobileinternet.tele2.ee or ask the operator
Than You
It solved the problem. Correct APN was “internet.emt.ee”.
