LtAP Mini on USB Powerbank
How long would a LtAP Mini last on a powerbank, say a 6000 mAh one?
What does mean mAh when no voltage is provided?
Check the product page to get the consumption…
No idea. Standard powerbank.
I know that any powerbank provide energy using 5v
(USB standard).
So, if you put it into microUSB using an adapter, should be works, but I not know for how much time.
Regards.
Well, according to the LTAP mini datasheet, it draws a maximum power of 9W.
That represents 1800mA current at 5VDC. So a fully charged 6000mAh power bank should last about 3:20h under perfect conditions. You should be safe assuming 2:30…2:45h realistically.
-Chris
Thank you, that’s great.
It lasted just under 12 hours, not bad.
