LtAP mini Software upgrade disabled LTE
Help please. New to Mikrotik so still fumbling my way around configuring them. Installed a new LtAP mini with Vodacom sim and straight out the box it worked perfectly. As recomended I upgraded to latest version of software (6.47.6). Router no longer connecting to mobile networks. Reading a few forums it seems as if the Router no longer “sees” the sim. In one of the menus I get error “modem not ready”. Some forums suggest that the sim is not inserted correctly but it is as it was originally when it worked. Also I have removed sim and tested elsewhere and it is fine. Another post I read commented on LTE passthrough picking up the mobile network settings from the Sim. I don’t know how or where to see what this is currently set at. Will downgrading to a previous version of software resolve this ? Now that I can no longer connect to the internet with the router, how would I “flash” the router to a version of software that may work. I am hoping someone can assist with a setting that I am overlooking.
Thematicus , please use ENTER to separate questions.
Fine means it’s work and you have internet back or not.
You not configure stuff what you not understand, at least not to many :).
This can be setup if ISP give you internet in proper way and you know that internet works well.
What?
“modem not ready” ? This is not reported to me at MikroTik lte modules, you not say what kit you buy or what lte module you insert/use.
More details please.
