ltAP with EM12-G slow LTE
I don’t have much details to share, but I got the EM12-G working in the bottom slot of the the LtAP
But the LTE performance is not what I’m expecting where I am - everything is kind of default - is there any tunning of the Card or maybe the router that I should look at?
As an example if I swap it for the EP06 its way faster - so I’m guessing it the config of the EM12
Start off by explaining what is your definition of “slow LTE”. Also check what kind of connection has LTE card with LTE network: RSRP, RSRQ, SINR, band, band width, etc.
Also try to test during small hours, public wireless networks can be pretty congested at times and statistics is saying that number of active users is the lowest during small hours.
Not sure it’s your specific issue. But one thing you may want to check the logs about “MTU” after the modem starts up. Sometime the MTU needs to be set lower, and generally the carrier will report the MTU in logs. MikroTik just logs this, but you can use the value from logs, to set the MTU on the lte1 interface manually. It only logs this once after the modem, so you may have to disable/enable the lte interface to see the log. If MTU is right…there will be NO log about MTU.
