LTE antenna visible in LAN
I have following configuration of my home LAN:
LHGG LTE6 - main and only source of internet
RB3011UiAS-RM - main router
cAP AC and wAP AC - home access points.
I have an issue with proper configuration of antenna and router, to have visible all device in one home LAN, in Winbox.
Currently LHGG LTE6 is setup a LTE client, so on LTE interface it has has ISP IP, for home network I have address for 192.169.100.1, devices connected to it has address from its DHCP, for example 192.168.100.10.
Router RB3011 is the only one device connected to LHGG LTE6 (ETH1 from LHGG is wired to SPF from RB3011 by RJ45 insert), so in such case on WAN RB3011 has 192.168.100.10 address. RB3011 has address 192.168.1.1 and AP and other clients have 192.168.1.x pool.
Here now is my main question, how should I configure LHGG LTE6, so do RB3011, to have LHGG with address pool from RB3011 192.168.1.x pool (for example static 192.168.1.100.) and it is also my main gate to internet access. In such case I believe on LHGG I should have double DHCP Client, but how to configure to move whole internet on RB3011 SFP port, which is also setup as WAN port.
I know there is some solutions with VLANs and passthrough, but I tried it on this configuration of hardware, so do with hAP AC3 and LHG LTE6 antenna, but it wouldn’t work…
You should use VLANs if you want to have few networks at the same device who have one Gigabit Ethernet port.
You can write me at Telegram.
/Zapraszam.
I know this solution with VLAN, but for my small simple home network I would like to avoid creating them.
Thanks and anyway I will write PM to you!
You can always use a SWITCH between devices, additional IP for future IP Access. Many ways of working even if you have one ethernet.
