Currently I’m using my “HTC Desire HD” phone for the internet connection via USB tethering with my “MikroTik RB2011UiAS-2HnD-IN” router. I’ve plugged it in and everything worked fine. When I remove the phone and plug it in again it will not work anymore.
- it’s not listed under “Interfaces” in Winbox
- on “IP > DHCP Client” an old entry with “unknown”-Device is listed
If I restore the backup which I have created during the running configuration it will work again.
In both cases the device is listed in the
/system resource usb print
output
