Hi all,
I’ve got wAP ac LTE kit and placed it at nice spot where I have full signal with cell phone under the same mobile operator, but I’ve found an issue which I don’t understand.
It’s frequently changing excellent cell for weak one. I’m not sure why it is happening as there are other cells with great signal. Can it be related to bands? How can I debug it?
EDIT: I was able to “fix” it using lock to particular frequency (earfcn). Now it stays on cells with strong signal.
/interface lte at-chat lte1 input="AT*Cell=1,3,,6400,"
Usual monitor ouptut. It doesn’t show cell 403 on B20 while I’m connected to it.
PHY-CELLID BAND EARFCN RSRP RSRQ AGE
162 B20 6400 -82dBm -13dB 1s
183 B20 6400 -88dBm -19.5dB 1s
450 B20 6400 -90dBm -18.5dB 1s
403 B3 1849 -107dBm -19.5dB 1s
162 B3 1849 -109dBm -19.5dB 1s
250 B3 1849 -121dBm -19.5dB 4s
Usual connection detail to cell with excellent signal.
pin-status: ok
registration-status: registered
functionality: full
manufacturer: "MikroTik"
model: "R11e-LTE"
revision: MikroTik_CP_2.160.000_v021
current-operator: Vodafone CZ
lac: 37030
current-cellid: 1073677
enb-id: 4194
sector-id: 13
phy-cellid: 403
access-technology: LTE
session-uptime: 27m25s
earfcn: 6400 (band 20, bandwidth 10Mhz)
rsrp: -78dBm
rsrq: -10dB
sinr: 7dB
Usual connection detail to cell with weak signal.
lac: 37030
current-cellid: 650246
enb-id: 2540
sector-id: 6
phy-cellid: 162
session-uptime: 17m5s
earfcn: 1849 (band 3, bandwidth 20Mhz)
rsrp: -110dBm
rsrq: -19.5dB
sinr: -10dB
