Hi everyone, im using EG18-EA LTE modem and problem is After a few hours of inactivity, the download speed drops to exactly ~5β10 Mbps and stays stuck there. If I manually reboot the MikroTik or run "/interface lte disable lte1" and enable it back, the speed immediately jumps back to a flawless ~192 Mbps.
What I have tried so far:
1. Locked LTE bands to B1, B3, and B7 to prevent the modem from dropping to the slow B20 (800MHz) band. It successfully aggregates B1+B3+B7 (3x Carrier Aggregation) after a fresh restart.
2. Signal numbers are excellent when running at full speed: RSRP is -82 dBm, and SINR is a very clean 21 dB.
3. Disabled 3G and Allow Roaming.
4. Set up a Netwatch ping to 8.8.8.8 every 1 minute to keep the cell tower awake. However, the tower seems to ignore simple ICMP pings and still throttles or drops Carrier Aggregation after a period of no real user activity.
Is there a known way to trick this specific carrier's cell tower into staying awake without breaking online game sessions? Or is there a specific RouterOS configuration/modem setting for the EG18-EA to automatically re-negotiate Carrier Aggregation when traffic requests increase, instead of staying stuck at 10 Mbps?
Which ROS version is running on device? Same issue was discussed on this thread: LTE18 and CA where changing RRC version with AT command helped to some, also is reported that latest ROS/modem fw version fixed issue.
Sounds to me like it might be a CA issue where the modem doesn't manage to pick up dropped CA channels. Your Netwatch ping once a minute is way too sparse, so try keeping CA alive with a short burst at least every 20 seconds, like:
If CA still drops, lower it to 10 seconds and send 5 larger packets instead. You can also raise the ping interval to e.g. 200ms if you want to spread them out. Try different settings until CA stays up.
If that does the trick, send a bug report to MikroTik support (support@mikrotik.com) with a supout.rif so they can take a look at the EG18-EA CA behaviour on 7.25.
You don't have to wait until tomorrow. You can check yourself how long it takes before the extra CA channels get dropped when there's no traffic, which should only take a minute or so.
Open WinBox (or WebFig), go to "Interfaces > LTE > lte1 > Cellular" and keep an eye on how long it takes before "CA Band" disappears when there's no traffic. It's usually under a minute.
Once you know the time, enable the ping task and check that "CA Band" stays active longer than that.
