i have a problem with my lte connection.
RB921UAG (mipsbe) with v6.40.5 and Firmware 3.41
the huawei device is registered and the interface is running, but it doesn´t get a dhcp address from the dhcp client.
The status is dhcp stopped and red and doesn´t retry for getting an address.
Release and Renew doesn´t work.
I have to deactivate and enable lte interface once so the dhcp client is searching for an address again
RSSI and ASU is good
that´s a huge problem because the routers are in the field and with no vpn connection we can´t reconfigure it without approaching the station
Well, it is not a “solution”, but it works for a while:
You can set a timer or a watchdog, that at a certain time or event (like no ping to internet anymore), the LTE interface goes down for 1 minute, and then up.
Ok I would not have guessed it also affects those cards (I have no experience with them).
My guess has always been that it is caused by drawing too much current from USB when the transmit power is at its highest.
This is backed by the fact that it usually goes down when doing lots of data transfer, and only when there is poor coverage.
At places with good coverage (so the transmit power is low) it seems to be working fine.
Maybe there is a similar issue with PCIe. Try to connect a better antenna or move the setup to a location with good coverage
and see if that fixes it.
i tried 4 Antennas until now, industrial standard
coverage is perfect, i have good rssi and asu values
also different providers
data transfer is very less, just a few mb a day
That is why I took a separate LTE modem (I cannot wait until Mikrotik comes with a LTE ready device (announced in I think summer 2017, still not here)). That is why I purchased a Teltonika LTE modem. It is a LTE modem with a WAN, LAN and WiFi ports / antenna’s.
It is based on Linux, and it can also do OSPF etc…
That modem is also used in mission critical situation in professional systems, like in tunnels, and other underground places.
sounds interresting, but we have already finished the project with about 350 Mikrotik Routerboards and Sierra LTE Modules in a wide area
worked fine in the beginning but now we have more and more trouble with the described problems and DHCP loss
