LTE + Ether1 gateway
Hi all! I have two ISP (one on Ether1 with DHCP on 192.168.8.1) and second on Lte ( DHCP 192.168.8.2)
I want to route all traffic from eth2/eth3/eth4 to ISP1, and all traffic from WI-FI to ISP2
I read some articles about mangle but can’t figure out how to use it in my case. Do I need to create separate bridge for Wlan1 and Wlan2? Thanks!
First seperate the networks of the two ISPs, as you mention both are on the network 192.168.8.0…
The simplest thing you can do is routing rules… https://help.mikrotik.com/docs/pages/viewpage.action?pageId=59965508
:face_with_monocle: but I want to keep same local network (for local device discovery)
my current config
# jun/17/2022 11:59:55 by RouterOS 7.3.1
# software id = XXXXXXXX
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXX
add admin-mac=XX:XD:X8:61:1E:X6 auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] name=lte1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-611ECA wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=MikroTik-DADDY wireless-protocol=\
    802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add interface=lte1 list=WAN
add interface=ether1 list=WAN
    192.168.88.0
add address=192.168.8.100/24 interface=lte1 network=192.168.8.0
add address=192.168.8.177/24 interface=ether1 network=192.168.8.0
/ip dhcp-client
add add-default-route=no interface=lte1 use-peer-dns=no use-peer-ntp=no
add add-default-route=no interface=ether1 use-peer-dns=no use-peer-ntp=no
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1 use-doh-server=\
    https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=1.1.1.1 name=cloudflare-dns.com
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat out-interface=lte1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.8.2 \
    pref-src="" routing-table=main suppress-hw-offload=no
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.8.1 \
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=lte1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Kiev
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
damn I can’t open this link - 50x error :frowning:
https://help.mikrotik.com/docs/display/ROS/Policy+Routing
Could you help? Can’t find where is my mistake. All traffic still going to 192.168.8.1 gateway. But I want Wlan2/Wlan1 to 192.168.9.1
# jun/18/2022 14:30:53 by RouterOS 7.3.1
# software id = L3R8-8803
add admin-mac=XXXXXXXXXXX auto-mac=no comment=defconf name=bridge
/interface lte
/interface wireless
    installation=indoor mode=ap-bridge ssid=MikroTik-611ECB \
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
/routing table
add disabled=no fib name=isp2
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes use-doh-server=https://1.1.1.1/dns-query \
    verify-doh-cert=yes
/ip dns static
    invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.8.1 routing-table=main \
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.9.1 routing-table=isp2 \
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup-only-in-table disabled=no dst-address=0.0.0.0/0 interface=\
    wlan2 table=isp2
    wlan1 table=isp2
/tool mac-server
The simplest thing you could do is create a second bridge for wlan1 and wlan2, assign an IP address to that bridge ( different from the one used now ), create a DHCP server on that bridge, and then on policy routing rules for that subnet use as table your ISP2 table.
thank you! that’s work
