LTE External antennas
Hi.
I have ordered the following antennas for my Mikrotik chateau 12. Unfortunately, the device does not detect them. Is it a problem of antennas or devices?
Technical specification of the LTE SMA 9DB antenna
Parameter Range
SMA connector
Length 28 cm.
The supported frequencies are from 800 to 960 MHz, from 1710 to 2170 MHz, from 2500 to 2600 MHz
50 Ohm impedance
Standing wave ratio 2.0: 1
Gain from 7 to 11 dBi
What exactly do you mean by “Unfortunately, the device does not detect them.” ?
winbox or cli,
interfaces, lte, modem, choose external antenna.
Default is none, you can choose auto, both, div or none
