LTE Huawei E3372?
I cannot get this one started.
Interface LTE shows nothing.
Nothing in logs.
RouterOS 6.41RC47.
Ubuntu reports this as
[23892.376108] usb 2-3.2: new high-speed USB device number 13 using xhci_hcd
[23892.481169] usb 2-3.2: New USB device found, idVendor=12d1, idProduct=1f01
[23892.481172] usb 2-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23892.481174] usb 2-3.2: Product: HUAWEI_MOBILE
[23892.481176] usb 2-3.2: Manufacturer: HUAWEI_MOBILE
[23894.424106] usb 2-3.2: new high-speed USB device number 14 using xhci_hcd
[23894.529062] usb 2-3.2: New USB device found, idVendor=12d1, idProduct=14dc
[23894.529065] usb 2-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[23894.529067] usb 2-3.2: Product: HUAWEI_MOBILE
[23894.529069] usb 2-3.2: Manufacturer: HUAWEI_MOBILE
on which board you test that?
Check if the usb port is added under system ports.
RB2011.
And no, nothing under system ports. Just the serial interface.
just Unplug Power wait few seconds then plug it back
Nope.
Model		2011UiAS
Serial Number		4CA904EC4A14
Firmware Type		ar9344
Factory Firmware		3.10
Current Firmware		3.41
Version		6.41rc47 (testing)
And
/port> print
Flags: I - inactive
 #   DEVICE NAME                         CHANNELS USED-BY                       BAUD-RATE
 0          serial0                             1 Serial Console                auto
It’s weird. I got it up running once. It showed up under /interface lte
But then I had to unplug the device, and now its not showing up again.
Have tried reboot router and unplug a couple of times without success.
are you using original OTG?
This was probably it. I was using a one dollar china cable :slight_smile:
