Lte interface can't recover after SIM-slot change command
Hello all,
I have an issue using a r11e-lte ltAP mini which has a dual sim slot.
If I request the modem to change sim slot the interface vanishes and will not reappear till a cold reboot (physically disconnecting power from the ltAP) a software reboot does not recover the interface.
USB power reset does not work either (I have tried upto a 300s delay).
Has anyone got a solution to this?
It’s like a hardware problem.
Please do a firmware upgrade https://wiki.mikrotik.com/wiki/Manual:Interface/LTE#Modem_firmware_upgrade
You can open box and re-install R11e card and re-install SIM card’s.
