Site to Site ipsec tunnel establishes a connection but traffic doesn’t arrive at datacenter over tunnel.
Current Equipment at client site. LTE Router / Modem in passthough
manufacturer: MikroTik
model: R11e-LTE-US
current-operator: AT&T
Firewall
manufacturer: UBNT
model: UniFi Security Gateway 3P
Local Network: 192.168.58.0 / 24
Subnet at our Datacenter : 172.16.58.0 /24
Cisco ASA55xx-X Netgen firewalls in Active - Passive. Currently host more than 2 dozen ipsec vpns, including this clients when it was on a Verizon FIOS connection.
I’ve attached a lot more of my notes in a txt file to this post so that it doesn’t blow out for screen after screen. At this point I feel like it’s either something I’ve not setup correctly with the LTE connection and pass-through (although I do get traffic, firewall see’s ip address on it’s interface, and I can connect to firewall using L2TP) I’ve placed a spare Cisco 5520 for testing and recieved simular results. It might be something to do with LTE and maybe I need to call AT@T, but I’m not sure how to point in that direction or how to get this problem routed to the correct technical source.
As with a lot of this kind of gear. it’s at a remote location for me to get at it. IE Fly to nearest airport and drive 2 hours. I can put more technical hands onsite, but I have to schedule that and if downtime is expected.. that needs to be considered. For the most part, the LTE / USG setup is working, Just no tunnel for the couple of services we need accessible.
My MikroTik setup for starters for the LTE looks like this..
/interface lte apn
set [ find default=yes ] apn=XXXXX.MCS passthrough-interface=ether1
passthrough-mac=74:83:C2:79:59:F5
Interface Info commnad output
/interface lte info lte1 once
pin-status: ok
registration-status: registered
functionality: full
model: R11e-LTE-US
revision: MPSS: R11eL_v16.02.183961 APSS: R11eL_v05.03.183961 CUSTAPP:
lac: 205
current-cellid: 166688024
enb-id: 651125
sector-id: 24
phy-cellid: 173
access-technology: Evolved 3G (LTE)
session-uptime: 9h14m28s
imei: 355509090174542
imsi: 310410283564344
uicc: 89014103272835643442
earfcn: 2000
rsrp: -100dBm
rsrq: -15dB
I’ve read a bunch of articles on this forum, UBNT’s etc. and I’m not sure where to look to get the right command to sort this out.
Notes to forum.txt (7.2 KB)
