LTE - Is there a good way to change the AD for the default route?
I’ve noticed that in the APN settings it asks if you want the default route and also gives you the option to set the AD for it. This seems to only apply for the LTE device (SXT LTE6 US) and doesn’t work when you use APN pass-through. When I use pass-through for the IPv6 address, it uses SLAAC but automatically sets a dynamic default route with an AD in 1 in the main routing table. The cellular internet is only to be used for backup purposes, so I am trying to set the AD greater than 1 preferably.
Is there any way to adjust this by chance? Unfortunately, with the /64 I’ve been given from T-Mobile I have to NAT all traffic via masquerade. Hopefully some year that’ll change so I can properly give all my VLAN’s their own proper prefix.
