LTE low speed
I use the wAP ac LTE6 kit and the speed is very low.
With my smartphone and 4G I reach 80/30 Mbit and with the LTE Modem maximum 40/10 Mbit, mostly only 35/5 Mbit.
What can I do, what should I check? It is the same contract.
I use the newest Modem Firmware R11e-LTE6_V027 and the newest Long-term Release 6.47.10
Kind Regards
Oliver
Compare RSRP and RSRQ values between your MikroTik and your smartphone.
By cable or by wifi?
The LTE inside the smartphone is… directly connected.
If the smartphone test the RouterBOARD LTE connection by wi-fi.. the wifi settings and hardware inside the smartphone can make the differencie…
Think about that…
Not nearly enough info.
For instance…
In the US near Washington DC.
Verizon Wireless most common channel was not supported by Mikrotik.
So it defaulted to a slower channel.
You talk about the region/state/country?
Because version and model are all declared: R11e-LTE6
2G Category Class12
2G bands 2 (1900MHz) / 3 (1800MHz) / 5 (850MHz) / 8 (900MHz)
3G Category R7 (21Mbps Downlinks, 5.76Mbps Uplink) / R8 (42.2Mbps Downlink, 5.76Mbps Uplink)
3G bands 1 (2100MHz) / 2 (1900MHz) / 5 (850MHz) / 8 (900MHz)
LTE Category 6 (300Mbit/s Downlink, 50Mbit/s Uplink)
LTE FDD bands 1 (2100MHz) / 2 (1900MHz) / 3 (1800MHz) / 7 (2600MHz) / 8 (900 MHz) / 20 (800MHz) / 5 (850MHz) / 12 (700MHz) / 17 (700MHz) / 25 (1900MHz) / 26 (850MHz)
LTE TDD bands 38 (2600MHz) / 40 (2300MHz) / 39 (1900MHz) / 41n (2500MHz)
