LTE ME909u-521 Mini-PCIe
Please, give me firmware program.
shed, please contact Huawei or look up in the Huawei support site if they have the latest firmware available.
I can not find it.
Please, help me.
please contact the Huawei support or ask the store where you brought the modem if they have newer firmware:
http://consumer.huawei.com/en/contact-us/index.htm?tag=email
I sent an e-mail to HUAWEI, but there is no reply.
I’m trying to find it, but that never found.
If you have the latest firmware program…
Please help me.
I got it working on RB411, but it doesn’t work with the RB912. The huawei modem isn’t recognised at all.
Isn’t it supported by the 912 board?
Make sure that the usb mode is set to the mini-pcie in the ‘/system routerboard usb’ menu.
I have a problem with ME909u-521 Mini-PCIe card and RB912UAG… for 4G internet access.
Everything seems configured , ping the google.fr pass from the interface of the mikrotik but not from my computer
have you a idea ?
Thank.
ME909u-521 Mini-PCIe : 11.235.07.00.00
RouterOS : 6.21.1
Did you and DCHP client to the LTE interface?
no, but i have already a ip adress on lte interface !
HI.
I have similar problems with this modem and I think there is a software bug in RouterOS or firmware of a modem
First:
I have a RB411UAHR (Mikrotik v6.23) with modem Huawei ME909u-521 in miniPCIexpress slot.
  1. Once I powered up a masine, the routerboard don’t discovered any modem in usb resources.
  2. I make a few resets (by winbox, terminal, or plugin power jack out) and then at one time I see the LTE interface in interfaces card. I unlock SIM card, set DHCP client on LTE interface and modem works fine.
  3. I make reset again and then I see only ppp-out interface (disabled), no LTE interface is present, but in resources in USB I see huawei modem.
  4. I make a few resets again and then I cannot see any USB modem in resources (and LTE interface of course)
  5. If I make a many resets, the modem will be (if it feels lucky :slight_smile: )discovered, but as interface LTE2 (or 3, 4 etc…) and needs new configuration.
6)I have two RB411UAHRs and two modems and the behavior is the same in different hardware configurations.
Here is three suppout.rifs - for Your aditional information. With LTE interface discovered. With LTE interface Not discovered, but in USB resource is modem present and with no modem presented in usb discovered.
Can you tell me a feedback of this information?
Many thx
K.
supout.zip (656 KB)
i have the same problem,but i have many RB411u ( routeros 6.11) instead.
can mikrotik’s team help out?
Hi We are sorry but ME909u-521 is not compatible with RB411U /UAHR in miniPCIe slot you need to use this
adapter it will work with this u http://www.ebay.co.uk/itm/Mini-PCI-e-Wireless-to-USB-Adapter-card-With-SIM-Card-Slot-Test-WWAN-module-/281397090670?pt=LH_DefaultDomain_3&hash=item418492d96e
for RB411 to work
ME909u works grate in RB912 boards.
MC7710 will work grate in RB411
I’m actually running ME909u-521 rev. 12.631.07.01.00 in RB411U (in minipcie slot - no adapters, LTE iface, ROS 6.27) without any issues.
Hey guys, do you have any pointer on what SMA antenna to buy?
thanks
Hi Raymond
For LTE we are using http://www.mouser.com/pdfdocs/Molex6BandCellularAntenna-2.pdf and it is working great
Take in account that GPS function is not working at all in any RB912. We can communicate with the GPS module of the RB but it never position with GPS. We have a ticket with mikrotik support for more than 2 months and we don’t have any answer in the last weeks.
Our guess is that mikrotik has some type of issue with pcie communication performance with Huawei ME909u-521
We have also RB953 and with this RB in optimal coverage situations GPS of the Huawei ME909u-521 gets position.
Best Regards
I’m using standard omni 5dBi (or 4dBi from RF Elements for outdoor - no hinge so no way for water to come in) wifi antennas (2.4GHz) and it is working reasonably well (for a network running on 1800MHz). With average LTE cell coverage I’m getting about -70dBm signals (outdoors) on that.
With a different provider and UMTS network running around 1.9 - 2.1GHz I can get up to -52dBm with the same.
have you solved this problem?
ME909u-521 never locks sats and just looping
$GPGSV,4,1,16,01,,,28,02,,,34,03,,,30,04,,,29*7A
$GPGSV,4,2,16,05,,,32,06,,,30,07,,,28,08,,,28*76
$GPGSV,4,3,16,09,,,32,10,,,29,12,,,28,13,,,32*71
$GPGSV,4,4,16,14,,,32,15,,,29,16,,,29,17,,,33*7F
$GLGSV,1,1,01,,,,26*60
$GNGNS,,,,,,NN,,,,,,*53
$GPVTG,,T,,M,,N,,K,N*2C
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GNGSA,A,1,,,,,,,,,,,,,,,*00
$GPGGA,,,,,,0,,,,,,,,*66
$GPRMC,,V,,,,,,,,,,N*53
$GPGSV,4,4,16,14,,,33,15,,,29,16,,,29,17,,,33*7E
Hi Stam
It doesn’t work
This problem can’t be solved, we spent hundreds of hours working with mktk support, trying different routerboards and 90 or 95% of the times the GPS doesn’t position
We are trying since March different antennas and all possible routeros version, I am quite sure RouterOS has some problem with low level Huawei mini-PCIe interface
You must look for other solution out of MKTK if you need a Mini-PCIe with LTE and GPS.
Best Regards
Dear friend,
I have RB912UAG and Huawei ME909s-120. When the card is recognized, everything works very good but if I turn off the router and turn on again then the card is not recognized until I go to System/RouterBoard/reset USB power for 5 seconds. After this, LTE interface appears again but this is a big problem. Router will be placed in a place with no skilled people to do this every time if the router is OFF/ON. If I just reboot then all is ok… If power loss then the described problem appears. Can You help?
Best Regards!
