LTE modem for band 42 (3.5GHz)
Recently We have developed a LTE network using the band 42 at 3,5GHz. We are using Huawei CPE but, in my opinion, it is a very simple CPE. Anyone knows about a minipci LTE modem or USB modem that could work with a Routerboard?
Thanks,
Miquel.
Did you find anything? I am interested too.
Nothing!
I would like to use this product https://na.baicells.com/nova-2x250mw/ it support LTE Band 42/43. “Anyone knows about a minipci LTE modem or USB modem that could work with a Routerboard?”
Bill
If you’re cell network operator, then this is a product for you to build your network. If you’re trying to use existing cell network to get internet, then this product is definitely not for you.
