LTE modem is R11eL-EC200AEU and is not recognized by RouterBoard RB912UAG- 5HPnD. I have installed modem into RouterBoard slot, attach Mobile and WiFI antenas, insert SIM card and plug power cable in.
After first start I have upgraded routeros to 7.20.4 and after restart, upgrade also Roterboard. Then I add extra package tor LTE, but modem is not showing into Interface list.
Have you done reset to factory conditions after putting all SW to latest versions ?
Sometimes startup script doesn't recognize device when everything is not at the correct version.
Is something shown in log ?
Other things to try:
reset USB (System - Routerboard - USB Power Reset, use 10s or so)
Sometimes the system starts up a bit too fast for the device to be recognized.
If this is the case, you definitely should make a support ticket for it.
manually add LTE interface (I've already had to do that after accidentally removing it)
Again: if this helps, create support ticket so they can check why it is not being populated from the beginning.
