Does anybody use Quanta 1K6E LTE USB (Beeline) modem with RB2011UiAS-2HnD-IN ?
I cant see any LTE or PPP interface.
try to unplug the modem, turn off the board, plug the modem back and only then power on the board.
Then check if you see a usb port recognized.
I’ve done it. But the USB port is not defined. On the menu System-Resorce is determined by the device
then make a support output file and send it to support@mikrotik.com
Could you help me with the firmware to this modem... Am kinda stuck with a bricked one
. If you could show me how to un-brick it, I would highly appreciate it
