I have a setup with 2 LHG R(2 different mobile provider) connected to a netgate pfSense gateway. One has a static IP, the other is on DHCP. Unfortunately the 1 minute lease-time is spamming the protocol on the pfSense and makes it quite useless.
Changing the value is not possible because it´s obviously dynamic. Is there a way to change this? I don´t want to hack the pfSense to silence the dhclient entries.
thanks
Philipp
anybody an idea? Should I write to support@mikrotik.com or in another group?
it is big problem
with /24 passthrough, mikrotik steal ip address from operator.
and my router flap interface when renew ip address
