LTE Qualcomm MDM9200
Hello
I’m trying to get working a LTE Modem based on Qualcomm MDM9200.
It is a minipcie format modem, that I use with a USB box.
Actually, when I connect it to my CRS109 and after a reboot, I see it connected to the usb port, but the lte interface is not created, and I cannot go further.
I added the lte package to ROS, but still does not work.
I added supout.rif, if someone can help !
I’m using v6.39.2.
Thanks a lot
supout.zip (402 KB)
i have issue with gobi 4000 modem. my modem is BLAZZ RX300, chipset is qualcomm mdm9200 (gobi 4000).
my questions are:
  1. is ros 6.44.3 support this modem?
  2. and, how to usb_modeswitch (in linux) with mikrotik? this modem has usb storage mode that prevent mikrotik to get to modem mode.
kindly appreciate all feedback.
I open this support.rif file in mikrotik.com > Account > support.rif viewer and I see:
model: CRS109-8G-1S-2HnD
current-firmware: 3.33
usb-mode: force-host
1 device="1:2" vendor="Qualcomm, Incorporated"
   name="Qualcomm CDMA Technologies MSM" serial-number="*****************"
   vendor-id="0x0408" device-id="0xea24" speed="480 Mbps" ports=0
   usb-version="2.00"
ignore-directip-modem: no
You must connect it and check it in RouterOS v6 and v7.
Good HowTo is this post: http://forum.mikrotik.com/t/quectel-ep06-e-and-wap-r-ac-rbwapgr-5hacd2hnd/131724/1 because many stuff with LTE modems are change in last year.
Good Luck!
