LTE routerboards
I have three routerboards with built in LTE.
One has a Tmobile Sim card and works fine. The APN is “fast.t-mobile.com
One has a Verizon sim card and works fine, The APN is “vzwinternet”
One has a ATT Prepaid sim card with 10 gigs ($50) on the account according to the at&t account login page.I have confirmed that my iemi is registered to the sim card, and they are both associated to this account.
The APN “phone”, “NXTGENPHONE”, and “Broadband” all get a IP address, but limited connectivity. I can’t ping , but I can do ns lookup against the assigned DNS and the browser on the connected PC gets redirected to
[u]http://redirect.ac.sl.attcompute.com/cgi-bin/redirect.cgi?msg=6[/u]
It says "AT&T Free Msg: It looks like you want to use data but have none available. You may need to add a data package or change to a plan that supports data for your device. To check your plan and manage your account, login to att.com/myprepaid.
This is with AT&T in many devices.
I have oposite situation, in R11e-LTE6 the broadband and NXTGENPHONE give me internet and works from fist use.
LTE module Telit LM940 give me the same problem what you have now.
I not found solution, please give feedback if you found it. Calling to AT&T not give me any clue.
https://forums.att.com give 410K answers at this sentence :frowning:
