LTE seems to de not working
Hi every one
I just connected a new XLE LTE Kit
laptop via LAN cable on ethernet1 port.
So far so good, I can start the web app and see all my default configs (see attachment)
Sim Card is inserted properly in the slot.
But my LAN Connection tells me no Internet
No DHCP needed, it’s only one device to be connected to internet via LTE out in the woods(there is a strong signal there).
I wonder that there is no Ip from LTE
admin@MikroTik] > /interface lte print
0 name=“lte1” mtu=1480 mac-address=AC:FF:FF:00:00:00 apn-profiles=default allow-roaming=yes network-mode=gsm,3g,lte
[admin@MikroTik] > /interface lte info lte1 once
pin-status: ok
registration-status: registered
functionality: full
manufacturer: “MikroTik”
model: “R11e-LTE”
revision: “MikroTik_CP_2.160.000_v015”
current-operator: A1
lac: 11905
current-cellid: 1313393
phy-cellid: 432
access-technology: 3G
imei: 355654093991714
imsi: 232011530222468
uicc: 8943015617276709331f
earfcn: 1700 (band 3, bandwidth 20Mhz)
rssi: -75dBm
What’s wrong?
Many thanks in advance!
mongoconf.rsc (2.81 KB)
…IP from lte will not show there, but can be examined under “/ip address print”, when the lte1 interface is up and running.
