I’d like to use a hAP AC Lite with a Sierra 7455 in a USB adapter.
I’m assuming I’ll have to tape some of the pins on the PCI modem, but which ones?
See http://forum.mikrotik.com/t/mikrotik-lte-sierra-wireless-mc7455/158170/1
You may also be able to flash the device to the latest firmware using a PC, the use AT!USBSPEED=0 to set USB 2.0 speed.
The hAP ac lite doesn’t have a miniPCIe slot. Only USB, and only USB 2.0. The Sierra MC7455 defaults to using USB 3.0.
