LTE + Wireless Support on RBM33G
I have a requirement to have a router that supports LTE + 2.4Ghz Wi-Fi, I want to use the RBM33G RB with the following MiniPCI-e cards.
  • R11e-2HPnD - for Wi-Fi
  • R11e-LTE6 - for LTE
Kindly confirm that the RBM33G RB can support both cards working simultaneously.
Well the product page says it can do this: https://mikrotik.com/product/rbm33g
So does the PDF: https://i.mt.lv/cdn/rb_files/1570517637RBM33g-qg.pdf
Only you need to remove the jumper on the board, from USB, to pass the energy to the second miniPCIe port and you will show both interfaces on WinBox.
Regards.
