M33G + 2x WLAN
Hi
I going to buy M33G with R11e-5HacT AND R11e-2HPnD to use 5 and 2.4 GHz at the same time. On 5GHz network will be 1 clinet and on 2.4GHz will be 2-4 clients. Could you tell me is this config is OK? It’ll be work fine?
Yes, but no new drivers for AC Radio!
What do You mean: no new for AC?
I mean you have to run ROS version 7 with the old drivers - the package wireless not wifi-qcom-ac package !
OK, thanks for advice!
