I have been testing M3P to see how well the packet aggregation improves things however I can’t see it improving anything so far. The tests are using the built-in bandwidth test over an EoIP tunnel. Setup I have is Mikrotik → Cisco Switch → Mikrotik and both Mikrotiks can see each other as MNDP neighbors. On the test I set the direction=transmit and local-tx-size=100. I test with packing and unpacking set to simple with an aggregate of 1500 on both ends but get the same results as when I have packing and unpacking set to none.
Is there something I am missing here? Does M3P still work when you run bandwidth test or does it only affect traffic passing through the Mikrotik?
Interestingly enough I just roled back to 2.8.28 and it works fine. Problem is that we need “interface bonding” which is only in 2.9. Is this a known bug? Any ideas on a likely fix date?
Good to see a fix for M3P in the latest release. I will try and test this some time this week. Also in the latest (2.9.7) is “fixed queue time limits”. Does this refere to the 15ms delay that M3P adds? If so can someone explain how this has changed?
Is there no way that the 15ms delay can be user defined or reduced? I know it’s the way that M3P does it’s thing but it would make sense for the delay to be less. I.e. Under heavy load M3P would easily be able to fill a 1500 byte packet in 5-10ms where as under lite load M3P isn’t so important as your not loading the link anyway.
