m3p + dscp
I need some advice on this
We have a ptp link with ubnt . Mikrotik both ends for routing
We push quite alot of voip on it
I’ve noticed if i enabled ip packing simple which drasticly reduces the pps load which is perfect
on the ubnt they use dscp value 48 for highest voice priority. If i do tcpdump on the ubnt the packets gets ignored, once i disable m3p, I can see the traffic with the correct ToS value
I thought ip packing would simply aggregate the packets and not change the packet header?
Can someone shed some light on this?
S
Hello, did you get an answer on this?
nope
ubnt tcpdump shows malformed info, only use packing when u have voip only clients or very high load pps rate. if only there was a way to tag the m3p packet to 48
S
