I have two RB SXT G5-HPnD r2 connwcted via wlan in nstreme 20/40MHz.
I am trying to get it to work with M3P (ip packing) on my two SXT in wireless link.
At first i have done like it said in http://wiki.mikrotik.com/wiki/Manual:IP/Packing.
Then I tried all options with “/ip packing” such as
“interface”, “packing”, “unpacking”, “aggregated size” from both sides
and changing wireless protocols.
But it does not work.
I really dont see the difference in work.
In “Interfaces List” packets have same counts.
I have tried it a few times too and always failed.
Discovery is enabled on both devices and they see each other. I wonder if it is the bridge that is the problem.
So on both devices I have bridge with ether1 and wlan1 in it. Taken from the wiki the ip packing must be on the interface seen in neighbour discovery, so my settings are like this :
This is done at both ends. When I click on the other device in the neighbours list it shows a line Unpacking : simple
At first glance it should work. I make bandwidth test with 64byte packets and watch the packets in the interface list, result - same amount of packets with and without packing.
