Hello
in my network i have my rb configure as ap bridge with wep key, i want to add mac address access control, because i saw a tool that can easily break wep key.
thanks for the answer
Hello
I dont know if this will help your situation. This is what i do. Use defualt authenticate. Say you have 10 clients registered, right click on their registration and copy to access list. Once you have done this uncheck the default authenticate and apply make sure to check registartion and make sure all clients are registerd. Hide SSID so you have to know SSID to find signal. Add a MAC for site survey van or whatever you may do. Maybe helps. i havent had network cracked through wireless yet ![]()
