i want to block MAC address for pppoe clients. i m using V3.13.
// chain=forward action=drop src-mac-address=00:21:27:C6:3B:8C Not working…
Any idea???
thnxs,
raktim
Any idea???
thnxs,
raktim
raktim -
First - upgrade to ROS 3.24, and be sure to upgrade the firmware as well after the ROS upgrade.
Second, try dropping them in the pre-routing chain instead of the forward chain.
R/
how can i sure that firmware is upgraded??? & what is the way to upgrade the firmware in x86 machine???
There is no prerouting option in filter rules. Do i need mark the connection first in Mangle???
thnxs,
raktim
there’s no RouterBOARD firmware on x86 =)
if you want completely block PPPoE client of your router - do it in ‘input’ chain, not ‘forward’
Not working, still logged in from this MAC.
0 ;;; test
chain=input action=drop src-mac-address=00:21:27:C6:3B:8C
pppoe is layer2, ip firewall can block only layer3.
To block layer2 traffic you can use bridge filters.
oops… really =)
