Re-posting from another forum in hopes of getting an answer quicker, sorry for the duplication.
Trying to get a MikroTik to auth properly against a RADIUS server. The issue is that, unlike other NASs we have, the MikroTik is transmitting the user’s mac address with colons separating each octet. This doesn’t work for us, because our user names are 12-digit mac addresses without colons.
How can I change this? I can’t find it in the manual and haven’t located it in the forums yet…I’m guessing that once I do find, I would also be able to make the Mikrotik transmit the mac as the password as well as the user name…?
Re: elongating the username…I could do that, but our other NASs don’t put the colons in the mac address. Thus, I’d have to have two usernames for each MAC in every table, one with colons and one without…
Unless I’m just missing something huge, which is possible, as I’m just getting by with RADIUS…any advice is appreciated.
Depending on your RADIUS server you could perhaps tell it to rewrite the username before trying to do anything with it. Perhaps in the style of “if a request from this NAS is coming in, delete all colons from the username”…
That would definitely work, if only I knew how to do it.
I’m using FreeRadius on Slackware. I have the Mikrotik dictionary included (with it’s reference to group commented out, as the “Group” attribute was defined in the general dictionary already).
Do you have any thoughts/advice re: how to perform that decision process you mention above?
Yes, thank you so much...I posted the following in that FreeRadius mailing list, but since it's totally about a Mikrotik I don't see the harm in including it here (a moderator may correct me, though - we'll see) -
The new NAS does not transmit a password along with the username, as illustrated below:
rad_recv: Access-Request packet from host 10.35.0.30:1034, id=50, length=60
In our AuthDB, every username (the 12 digit mac, no colons) has a password that exactly matches the username.
I tried to do this (and correctly loaded the module this time, thanks again to Dustin Doris):
#attr_rewrite blank_password {
attribute = User-Password
searchin = packet
searchfor = ""
replacewith = User-Name
ignore_case = yes
new_attribute = no
max_matches = 10
append = no
However, as I mentioned, that totally broke every other Auth-Request in addition to not validating the new NAS Auth-Request in question.
So my boolean would be, "IF an Auth-Request comes in (??"from a particlar client"? or "from a particular shortname defined in clients.conf"? or would it be "with a blank password") THEN replace User-Password with (no colons, all lowercase) User-Name."
OR would I replace it with the User-Name as passed from the NAS and then operate on the password?
