MAC Auth
I have hotspot setup and it woks fine with chap login but i have so far been unable to get mac auth to work.
Do you put anything into the macauth password box? If so, what?
I assume that the mac address of the user goes into the mac box located in hotspot->user. Is this correct?
Is transparent proxy supposed to be checked or unchecked?
open status page=http login or always on?
Radius on or off? I would think off since i have set up users in hotspot.
Ok, finaly figured it out after 3 wiki articles.
Hi.
do you mine posting the exact link … i plan on mac auth. too …
thanks
don’t put anything in the password box. Only put the mac address in the name box all uppercase. No password though.
