I love this new feature.
My question is will this be able to work with the Rate-Limit attibute?
So I can set clients up to burst.
I do this now with pppoe. And would love to move over to this new feature.
I am playing with it right now authenticating via Vircom Radius and Rodopi.
I can set an Ascend-data-rate I see it set a limit on the user in the reg-table but the upload does not get limited only the download.
I would love for the Rate-Limit to work and show up in simple-queue.
Wireless Ascend-data-rate (ascend-xmit-rate) attirbute sets the same configuration as default-ap-tx-limit and default-client-tx-limit, limitation for both upload/download works only when MikroTik RouterOS is used as client, as well burt is not provided.
Use additional service like DHCP or HotSPot, if you wish to use ‘rate-limit’ attribute. ‘rate-limit’ attribute overrides ascend-data/xmit-rate option.
Is it rate-limit or is it Mikrotik-Rate-Limit ? I’m still having the problem where Mikrotik only takes the first four characters of the Mikrotik-Rate-Limit value from vircom radius.
Look at the RADIUS client documentation or at the MikroTik RADIUS reference dictionary, Mikrotik-Rate-Limit is used to create dynamic queues for the clients.
I am using Mikrotik-Rate-Limit and it will set the queues properly, but I’ve still got the problem where Mikrotik will only take the first four characters , no matter what they are.
