Hi all,
My network is as follow:
CRS 125-24G-1S-IN ----> ether6 ----> dumb switch (no VLAN capabilities) ----> IPTV decoder (and many other devices on the switch)
The dumb switch has 8xGbit ports and 6 of them in use.
Now I know my ISP sends IPTV over VLAN 303 (DHCP), and it seem’s my router should be able to only allow the IPTV decoder into the VLAN.
The problem is I don’t know how-to set this up. I’d also like to setup an IGMP proxy to proxy all multicast IPTV streams to the local lan (so that I can use Tvheadend on my server aswell).
My current config is as follows:
[joel@MikroTik] > export compact
# jul/18/2016 14:43:35 by RouterOS 6.35.4
# software id = 4ZWJ-QVRS
add name=bridge1
set [ find default-name=ether3 ] comment=Kontoret
set [ find default-name=ether4 ] comment=Dunder
set [ find default-name=sfp1 ] comment=WAN mac-address=E4:8D:8C:A6:C0:67
/ip neighbor discovery
set ether3 comment=Kontoret
set ether4 comment=Dunder
set sfp1 comment=WAN
add name=dhcp ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge1 lease-time=3d name=dhcp1
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=ether17
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24
/interface ethernet switch mac-based-vlan
add new-customer-vid=303 new-service-vid=303 src-mac-address=44:AA:F5:5F:89:5A
set 0 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 1 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 2 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 3 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 4 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 5 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 6 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 7 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 8 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 9 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 10 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 11 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 12 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 13 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 14 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 15 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 16 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 17 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 18 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 19 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 20 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 21 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 22 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 23 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 24 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
set 25 per-queue-scheduling=wrr-group0:1,wrr-group0:2,wrr-group0:4,wrr-group0:8,wrr-group0:16,wrr-group0:32,wrr-group0:64,wrr-group0:128
add ingress-mirror=yes ports=ether24,sfp1 vlan-id=303
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=sfp1
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
add chain=forward dst-port=80 in-interface=sfp1 protocol=tcp
add chain=forward dst-port=443 in-interface=sfp1 protocol=tcp
add chain=forward dst-port=22 in-interface=sfp1 protocol=tcp
add chain=forward dst-port=32400 in-interface=sfp1 protocol=tcp
add action=drop chain=forward disabled=yes
add action=masquerade chain=srcnat comment=MASQ out-interface=sfp1
add action=dst-nat chain=dstnat dst-port=443 in-interface=sfp1 log=yes protocol=tcp to-addresses=192.168.1.10 to-ports=443
add action=dst-nat chain=dstnat dst-port=80 in-interface=sfp1 protocol=tcp to-addresses=192.168.1.10 to-ports=80
add action=dst-nat chain=dstnat dst-port=22 in-interface=sfp1 protocol=tcp to-addresses=192.168.1.10 to-ports=22
add action=dst-nat chain=dstnat dst-port=32400 in-interface=sfp1 protocol=tcp to-addresses=192.168.1.10 to-ports=32400
add action=masquerade chain=srcnat dst-port=22,80,443,32400 protocol=tcp src-address=192.168.1.0/24
add action=dst-nat chain=dstnat dst-address=!192.168.1.0/24 dst-address-type=local dst-port=22,80,443,32400 protocol=tcp to-addresses=192.168.1.10
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set www address=192.168.1.0/24
set ssh disabled=yes
set www-ssl address=192.168.1.0/24
set api disabled=yes
set winbox address=192.168.1.0/24
set api-ssl address=192.168.1.0/24 disabled=yes
/ip upnp
set enabled=yes
/system clock
set time-zone-name=Europe/Oslo
/system routerboard settings
set protected-routerboot=disabled
[joel@MikroTik] >
